Question about Garden
Snapper Rear Engine Riding Mower 2008.. has been in shop three times for same problem. When on an incline and you engage and disengage the clutch/brake you hear a metal grinding noise and the mower lurches forward. Also clutch slips. slow in pulling froward and sometimes if on an incline wont' back up at all. Tighten the clutch spring and helped for short period of time.
  • Gerald Gier Apr 23, 2010
    This is a new mower 2008
  • Gerald Gier Apr 24, 2010
    There is a brake piece that is mounted inside the "driven wheel" which is what I believe you are referring to as the "clutch".. Have you experienced any problems with the brake assembly? There is still plenty of rubber left on the "driven disk" No metal to metal contact there.
    Guru:
  • 722 Answers
G502,
Have you actually replaced the clutch? If not, give that shot. It sounds like the clutch is slipping and after so many adjustments it may be time to replace it. If the clutch is hydrualically activated, try replacing the "slave cylinder". If it's a manual clutch (cable) then try replacing the cable itself.
Also, check or have checked; the drive axles (if any) or the component that drives power to the wheels. The mower should have some sort of actuator as well that activated the blades. This may be drawing so much power from the engine that there's not enough to drive the mower itself, and is distributing all the power to the blades.
If it has an actuator, it may be weak and loosing it's viscosity. Some of these are calibrated by air pressure, others are driven or operated electronically.
Contact the dealer (manufacturer) for more details or a repair/service manual if available.
Please let me know if you need any further assistance with this matter.
Cordially,
carsandcomps
Guru, Premium Expert @fixya.com
Posted on Apr 24, 2010
    President:
  • 1,851 Answers
You most likely need an inner clutch adjustment or a new clutch. They do go bad sometimes early. I would let them look at it under a warranty/RECALL umbrella. If you're 100% sure you would have to pay for it then that is different. It appears the clutch is shot and it is metal to metal causing it to **** and grind. There are only so many parts to look at and grinding is always the clutch because that's the only two surfaces that can grind - - the clutch plate meeting the clutch disk.
Best of luck with an other wise fine mower I am sure.
  • 666 Answers
This is a transmission problem if you have had it worked on several times I dont know why exactly the mechanic would not suggest buying a new or refurbished one as maintenance once they are past there prime becomes very costly I would look into buying a refurbished if everything else is okay and if not maybe look at getting a new mower entirely as the cost of work is only going to go up at this point
hope this helps
Robb
Posted on Apr 23, 2010
The blade on my snapper riding mower disengages but will engage by resetting. it then disengages again
My experience has been the clutch is bad. There is a "clearance gap" between the clutch pads so when it energizes a magnet is charged drawing the two together. When the clearance exceeds a certain amount, the clutch either will engage and almost immediately stop or not engage at all. Costly, too.
Jun 25, 2016 | Snapper Garden
Simplicity. How do I test the interlock module?
snapper mower:interlock module - how test?
www.homeownershub.com > Home Repair
May 28, 2005 - 1 post - ‎1 author Snapper 1438H Hydro, rear-engine riding mower. Thing yesterday just quit. ... Next item up the line is the INTERLOCK MODULE... All the safety ..
Sep 05, 2015 | Garden
Why will my Snapper riding mower not go into gear?
If it is a hydro-stat transmission, the bypass lever will have to be re-engaged for it to work.
Aug 23, 2014 | Garden
Snapper 23 series mower blade will not engage
sounds like you belt is disengaged or just wore out, these type belts look good just to look at them, but they can stretch and get rounded a little bit of can mean a lot
Apr 05, 2014 | Snapper Garden
Snapper Rear Engine Riding Mower 2008.. has been in shop three times for same problem. When on an incline and you engage and disengage the clutch/brake you hear a metal grinding noise and the mower lurches...
if they have been adjusting it for you this many times they have done it wrong and have ruined the clutch face plate material by letting it slip and sand off the facing material,now its down to the metal back plate and its now metal to metal,you need to have the clutch replaced soon or your going to ruin more drive components
May 02, 2010 | Garden
I have a Snapper rear engine riding mower. Mod#28085S
If one goes to the starter, the other has to come from a 12 volt source, either ignition switch or battery
Oct 04, 2009 | Garden
I have an 89 snapper riding mower . all of a
Check the springs, and nuts, and see if the pulley moves and doesn't stick when engaging/disengaging
Jul 20, 2009 | Garden
Garden Logo
152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
