Question about Acer Aspire 5610-4648 Notebook
Unbooting issues mine is an acer aspire4730z lapotop. now its not booting,when i switch on the power button a black screen with erro is coming.something like PXE ROM, check cable etc and last "no bootable device found insert cd to boot from cd", are written there.but if i enter into BIOS and if simply saved using f10 then ican use it as usual.while working if i restart ,it will restart without any fail.if i shut down and after if i try means again problem will arise.my battery backup is also decreasing.sir , requesting you to provide a good solution and what can i do.....
  • SANDEEP C V Apr 23, 2010
    wats the cost of that battery wich u mentioned... means CMOS battery...
    Brigadier General:
  • 10,406 Answers
Your computer has a list of devices to _try_ to "boot" (start-up):
* 3.5' diskette
* USB device
* USB-connected external CD-ROM
* your C: drive
* the internal CD/DVD
* over the network, if your computer's network-port is connected to a network-accessible boot-server.
So, the error-message means that either:
* the "order" of devices _excludes_ your C: drive
* your C: drive is "dying" -- and does not _always_ respond
* the tiny battery on the computer's motherboard is "dying", and it's "forgetting" the BIOS settings, including the fact that the C: drive is available.
When you enter BIOS-setup, your computer "finds" your C: drive, and everything works fine, even when restarting.
So, first get a qualified technician to replace the battery on the motherboard.
>> my battery backup is decreasing
This is an _independent_ problem -- the battery is not recharging as quickly as when it was new, and it does not hold a charge for as long as it does when it was new. Replace it, if you need to frequently use the computer via battery-power.
Posted on Apr 23, 2010
Wont boot bios windows
Try pressing F8 while the laptop is booting and select "safe mode". If it boots fine in safe mode, it might be either driver issue or the laptop's videocard giving up. The driver issue is corrected by installing the right drivers, you can ensure if the problem is on the hardware side by setting it to boot in 640*480*256 (or lowest possible resolution) and see if it boots. Also, try pressing F8 during boot and select the option to log the boot process. The log file might then tell you what causes the stop/hang.
Oct 23, 2013 | Acer Aspire 5738Z-423G32Mn Notebook
My hp g61 will only display a blank/black screen with the cursor after it has finish booting
That cursor is the way in which the BIOS of the laptop is telling you that Windows is completely corrupted and unbootable. You will need to reinstall it so use the recovery cd that came with the laptop.
Dec 28, 2010 | HP G60-120US Laptop
AOA150 acer asire one won't boot up at all. Have
when the screen is black try hitting ctrl alt delete a few times and you should get some options to work with
Apr 04, 2010 | Acer Aspire 3100-1405 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Computer does not boot
After replug the graphic card and switch on the pc & install back the graphic ... The power button remains green but the screen is black. ... From what i have noticed there is probably some issue with the thermal cutout ... Lights light up, Drive sounds as if working,
Jun 19, 2009 | Acer Aspire 1691WLMi Notebook
Screen black wont boot up
If it is new and under warranty. Use its warranty.
Apr 14, 2009 | Acer Aspire 5100 Notebook
Why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Feb 24, 2009 | Acer X193W LCD Monitor
Laptop Screen
thats mines ur screen cable has been brok from the inside of laptop if u have in warrenty then take it the compnay service center or if u have finished warranty pedior then go with professionl repairer of lapotop
Oct 11, 2008 | Acer TravelMate 2300 Notebook
Screen black
toshiba cosmio f10 laptop screen is not working. Totally black. from start nothing there. just black.
Dec 09, 2007 | Acer Aspire 5100 Notebook
Acer 4200 series
find some one with a charged battery and boot up then. check your battery for a charge.
Nov 19, 2007 | Compaq Armada M700 Notebook
Acer Aspire 5610-4648 Notebook Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
