Question about Linksys Wireless-G WRT54G Router
I have a WRT54G Linksys Wireless Router and can not VPN or Remote to a server from behind it
  • 550 Answers
It is a passthrough router. you can not create a tunnel using this router. Now if you are using any VPN software to connect to the network then you can try to open the ports on the router.
Reduce the MTU to 1365.
open the ports - 500 , 443-447, 1723, 10000-2000
Try this.
If your router is old then upgrade the firmware of the router.
Posted on Apr 24, 2010
  • robert w
    robert w Apr 24, 2010
    Click her for more information about router and networking
    Brigadier General:
  • 10,406 Answers
Connect to the web-server "inside" the router, and click the 'Status' button, and then the 'log-files' button. Enable "all" logging-options, and then try again to use VPN. Then, "view" the log-file, to see if any error-messages (or "blocked" TCP/IP packets) have been recorded.
Posted on Apr 23, 2010
Download software
http://support.linksys.com/en-us/support/routers/WRT54G
Oct 24, 2013 | Linksys Wrt54g-tm Wifi Wireless Router,...
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
My router is turning on and off and I'm not able to connect to the internet with it.
Repair, Maintenance & Service
' /* * For text ads, append each ad to the string. */ for(i = 0; i ' + 'Ads by Google' + '' + google_ads[i].line1 + ''; url = '' + google_ads[i].visible_url + ''; info = makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
'; s += url + info; s += ''; } s += ''; } document.write(s); G_GGL_SKIP += google_ads.length; return; } var G_MAX_ADS_WL = 1; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "2438490332+3956627698+7726281721"; google_ad_output = 'js'; google_max_num_ads = '1'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Ads by Google Network: Router Ssl Vpn Juniper.net/Router+Ssl+VpnClientless Remote Network Access for Enterprises
Jan 05, 2011 | Linksys Wireless-G WRT54G Router
Im tryig to piggyback my wrt54g router to another part of the house. I have a cable coming from my linksys e1000 n router which is my main router. When i plug the cable into the 54g i can access the router...
What is the IP address of the E1000 router ?
If the IP address of E1000 router is 192.168.1.1, Then change the IP address of WRT54G router to 192.168.1.2. Connect the Ethernet cable from the Ethernet port of E1000 router to the Ethernet port of WRT54G router ( port 1 of E1000 to port 1 of WRT54g). Disable the DHCP server.
You can do it in a different way also.
If the IP address of E1000 is 192.168.1.1. then change the IP address of the WRT54g to 192.168.2.1. Do not disable the DHCP server of the WRT54G. Connect the E1000 to the Internet port of WRT54G.
Click Here to know more about router and network
Sep 03, 2010 | Linksys Wireless-G WRT54G Router
VPN established but can't see the server on the other per
I didn't solve the problem using HB LB-2. I just change de router by linksys RV042 and the access
through VPN is ok.
Jun 16, 2009 | HotBrick LB2-VPN SOHO 4-Port Dual WAN VPN...
VPN drops when using a D-Link Dir655 router
Hi! Try to logon to the configuration page of your router. then go to Advanced tab and click on Firewall settings on your left side.
At the bottom part you could see the Application Gateway Level section, Uncheck all the boxes under that and click on Save Settings at the top.
Mar 06, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can't connect to AT&T VPN
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Mar 04, 2008 | Trendware 54Mbps 802.11g Wireless AP
Linksys Wireless-G WRT54G Router Logo
137 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
