Question about HP DeskJet F380 All-In-One Printer
NO LIGHT (SCANNER LIGHT) , LOADS PAPER ATTEMPTS PRINTING, SCANNER NOT FUNCTIONING ? ANY ADVICE ? THANKS, -KC
It is saying please open the bottom tray when printing but it is open?
open and replace with paper. That mainly happens also when paper is stuck coming from that tray. open the back of the printer and pull paper out!
kc
Feb 23, 2011 | Canon iP4500 Photo Printer
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
HP DeskJet 1560 - multiple paper feed
This link may not help you to print duplex, but it will possibly explain why you're having problems...Make sure you fan the paper before loading it. You might try putting a fan on it to dry out the ink as it prints...or try a heavier paper. Good luck! If you google duplexer feed problem you'll see this is the subject of numerous patents and attempts to resolve the very difficulty you are having.
(Maybe another of the same model would work better? Hp should exchange it if it's not working, no?)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2009 | HP D1560 Deskjet Printer InkJet
Printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
May 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Not printing
have you tried to replace the ink cartridge?
if ink cartridge is new yet it's not printing, try to print a test page by going to Start>Control Panel>Printers and Faxes, then right click on the printer icon with a check mark on it, select properties.. then click on "Print test page".. if it prints or loads a paper but it's blank, then it means the printer is working, it may have run out of ink..
If it doesn't print, or doesn't load a paper, most likely there's a problem with the software for the printer.. you may have to re-install the printer drivers..
May 09, 2009 | Epson Stylus Photo 1200 InkJet Printer
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Kodak 2500D error
I have had the same problem. That error represent a document still in the scan path. You will probably find there is no paper in the scanner. I tried this and it works every time. On the top of the scanner there is an access door. You will find this just above the discharge rollers. Open that door and either blow air in the compartment or blow hard using your mouth to clear dust. Close the door. That should resolve the problem. It is my guess that dust collects on sensors and the scanner is tricked into thinking there is paper in the path.
Jan 04, 2008 | Kodak Digital Science 2500D Path-Through...
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
