Question about Acer Aspire E380 ASE380-UD500A PC Desktop
Installing HDD Have an Acer E380 want to add a second harddrive to it, how do I do it? the machione came with no manual on what wire to use I have the drive put it in the machine just can't figure out how to connect it
  • PaulJustPaul May 31, 2008
    I know how to connect hardrives on my old computer, but on this Acer Aspire e380 the power cables get in the way because the entry to the harddrive housing faces inward. Also, the cable I need to read data is being used by the dvd player and the second head doesn't reach where I want to put my harddrive.
    Genius:
  • 3,587 Answers
Well..the power supply is most likely ok..what you'll need is an interface cable, which is of one of two kinds..if it's new, it's a SATA drive cable, otherwise, it's going to be Eide or IDE..
are you certain that drive is compatible?
Posted on Mar 23, 2008
Cant install server 2012
Hello download a manual from the homepage:
http://www.supermicro.com/products/motherboard/xeon3000/3210/x7sbe.cfm
Check the settings in the bios.
Try to reset the bios to factory default.
And setup basic boot settings for the drives.
First boot device: cd/dvd
Second: the harddrive.
Try installing with only one harddrive (you can always add more later)
Check also the cd/dvd drive for fault.
The Os server 2012 is supported.
Good luck
Nov 22, 2012 | SuperMicro X7SBE Server Board -...
Hp p6/2100 how to add second harddrive
Easy...
Juste connect the hdd by the bottom... and add the sdd like the picture !
May 08, 2012 | HP Pavilion p6-2100 Desktop
Installing Vista Home Basic at clean install got an error code 0x80070057 Windows could not format a partition on disk 0 the error occurred while preparing the partition selected for installation _____...
this sounds like a hardware issue, i suspect the harddrive. Try formating it and running diagnostics form a hDD external enclosure. Run a full scan disk and then format it form there before initializing it and back to the laptop for full installation of Vista
Sep 22, 2011 | Acer Aspire 5742Z-4200 Notebook
I WANT TO KNOW HOW TO ADD A SECOND HARDDRIVE TO MY GATEWAY ESSENTIAL 500 COMPUTER
If your additional Hard drive is SATA use SATA cable and SATA power to get it done.
Or else use IDE and D type power to connect.
Make sure that you have switched off the computer before installing the HDD
Thanks,
Satheesh
Jan 21, 2011 | Gateway Essential 500 PC Desktop
I have an Acer Aspire E380 desktop. Does it
It should not matter as long as the antenna is not surrounded by metal.
May 08, 2010 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Which hard drives are compatible with aspire e380
Up to a 400GB SATA harddrive.
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE380/AspireE380sp2.shtml
These are examples of SATA harddrives,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=139&name=Serial-ATA-Hard-Drive&
Note* Suggestions
When buying a harddrive it is best to,
1) Look for the right amount in size, but also look for one that has the largest Buffer.
The Buffer is the cache for a harddrive.
The buffer area is a small memory area.
It is the first memory area the device looks for.
The larger the Buffer, the faster the harddrive will be at gathering, or giving information.
2) Spindle Speed:
Normal spindle speed has evolved to 7200 RPM. (Revolutions per Minute)
Older harddrives were 5400 Rpm, and even slower.
There are newer harddrives out with much faster spindle speeds. 10,000 rpm on up.
Unless you are a full time gamer, with wanting to have the fastest computer possible around for gaming, there is no need for a harddrive faster than 7,200Rpm.
[If you are not aware of how an average harddrive's mechanical makeup is constructed;
Inside the harddrive case are Platters. These Platter's resemble CD disks, and are constructed of highly polished metal, or glass.
The Platters rotate on a Spindle. The construction is akin to a record on a phonograph.
There are 3 to 6 Platters, and maybe more with newer harddrives.
EACH Platter has a ReadWrite Head above it, and Below it.
The Read/Write Head does just what the name implies. It reads information off of the Platter, and can write information to the Platter.
Each Read/Write Head is attached to an Arm. The Arm sweeps the ReadWrite Head across the Platter.
When the harddrive is operating at full capacity, the ReadWrite Head can be moving across the Platter, at Hundreds of Times a Second!
The Read/Write Head is located above the Platter at a distance, that is around 1/6th the thickness of an average human hair.
(Approximately .0005, or can be said as 5 ten-thousandths of an inch. An average human hair is .003 thick. {3 thousandths)
Between the distance from the Platter, and the fast movement, there is a cushion of air formed in-between the Read/Write Head, and the Platter.
The Read/Write Head literally floats above the Platter.
The Platters are coated with a magnetic media. In otherwords this media can be magnetized.
The Write portion of the Read/Write Head arranges this magnetic media in a pattern.
The pattern is a series of 0's and 1's.
Zero being Off.
One being On.
More information about harddrives can be found here,
http://computer.howstuffworks.com/hard-disk.htm
3) If your SATA harddrive comes with a 4-pin Peripheral power connection, AND a SATA 15-pin power connection, ONLY use the 15-pin SATA power connection!
I will give a link to both the 4-pin Peripheral power connector, and the 15-pin SATA power connector in an additional comment.
Apr 22, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
How can i add additional hard disk in to my acer aspire 6930g , I tried to do it but the cover doesnot close after putting the hardisk into the laptop, Any solution?
Or you guys could stop being ******* RETARDS and learn that Acer 6930G actually has second drive bay in lower left corner for installing secondary hdd.
You will need to get two(three counting connector) extra parts from Acer though: new cover (old one doesn't fit, metal mounting plate and connector.
Jan 08, 2010 | Acer Aspire 6930-6771 Laptop
Acer aspire 3000
Have you tried to disconnect the external monitor and just booting to the laptop? If this works, then use the "e" key next to the power button to add the second monitor.
Jun 20, 2008 | Acer Aspire 3000 Notebook
Don't have HDD passwords
To clarify the request, it is a harddrive password not a bios password or windows.
Jun 10, 2008 | Acer Aspire 3680 Laptop
Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
