Question about IBM Infoprint 1120 Laser Printer
We are getting this message on the printer 922 Service. What is this?
922 service fuser error
  • 921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
    • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
    • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
    Nov 10, 2010 | Lexmark T522 Laser Printer
    I am getting a 922 service fuser error on my lexmark optra s 1855
    922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
    Aug 26, 2010 | Lexmark Optra S 1855 Laser Printer
    My all in one dell 922 printer won't print. I
    try change the USB cable, to high speed quality Cable.
    Jan 03, 2010 | Office Equipment & Supplies
    922 service error message, what does this mean? Can I fix it myself?
    Sep 29, 2009 | Lexmark Optra S 1255 Laser Printer
    I'm trying g to connect my Dell AIO 922 printer to
    You need to go to Control Panel add/remove programs and remove all Printer programs. Then disconnect the USB cable, install the printer software until a message comes up that says plug in your printer. If no message comes up, complete the software installation and then plug in the USB cable. The computer should find the printer at this time.
    Aug 15, 2009 | Epson Stylus Photo R200 InkJet Printer
    Error message: color cartridge missing on a Dell 922
    try another cartridge. if that works then you have a bad ink cart, if not, the sensor is bad, replace the printer.
    Dec 30, 2008 | Dell 922 All-In-One InkJet Printer
    New cartridge
    Clean the copper contacts of the cart and reset back in the printer and if your getting the same error message please replace the cart with another cart .......
    May 13, 2008 | Dell 922 All-In-One InkJet Printer
    Dell 922 All-in-one printer has message on printer saying head error
    can you provide the error message, depending on the error and if you want to attempt to repair it yourself? Printers are like computers these days you can almost replace it for the repair cost, but if you will provide a error code we can see what we can do.
    Dec 26, 2007 | Dell 922 All-In-One InkJet Printer
    Dell 922 "cover open" problem / error message
    I had that problem too.
    Unplug the printer.
    Hold the printer cover open while you plug in the printer.
    Then close the printer after it powers on.
    It worked for me.
    Dec 04, 2007 | Dell 922 All-In-One InkJet Printer
    IBM Infoprint 1120 Laser Printer Logo
    19 people viewed this question
    Top IBM Office Equipment & Supplies Experts
    James Cagle
    James Cagle
    Don  Farrell
    Don Farrell
    CheckitRight
    CheckitRight
    Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
