Question about Maytag MGR5750 Gas Kitchen Range
Baking display malfunction
My oven display keeps showing 5 ab when I try to bake I was trying to set the clock then it started showing that and I unplugged it and still no luck my model number is MGR4451BDB and serial # is 14419155NA
  • 796 Answers
Its likely sab as in Sabbath mode.
Here is your online use & care manual which explains all about the Sabbath mode on page 15:
http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf (http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf)
Posted on Mar 23, 2008
    Guru:
  • 1,894 Answers
You will have to do a reset for clearing the error code
  • 1 more comment
  • dewan nafees ahmed Mar 23, 2008
    Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
    To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
    Here is a useful tip in identifying a frequently reported problem
    on some model ranges and wall ovens equipped with an Electronic Range
    Control (ERC) or Electronic Oven Control (EOC). An “error” code display of “Sabb" or “Sab” will be displayed and the range or oven will not function. This
    is called “Sabbath Mode" and it may be costing you unnecessary charges
    in service call fees. This is NOT a problem, but actually a feature
    provided by some manufacturers to enable customers of certain religious
    faiths to honor the Sabbath. The range will not function at all during
    this period and cannot be reset by unplugging the unit or turning it
    off. In your owner/operator's manual there should be a section that
    refers to "Sabbath Mode" under the control panel features and
    operation. This "problem" is a minor operator issue and is not a malfunction of the appliance. This
    is commonly reported by customers to service companies to have
    corrected, but the repair is unnecessary, and usually NOT covered under
    the manufacturer’s warranty. The reason: It is a designed feature of the appliance and considered “operator error” in most cases. What
    this means is you may be paying someone big money to push a couple of
    buttons and “fix” something that could have taken you minutes to
    correct yourself. Sabbath Mode can inadvertently be
    activated by pressing the wrong sequence of control panel buttons, kids
    playing with the control panel and also after a power outage. The
    “problem” can be cleared, but you will have to find the proper
    reference in your owner operator manual. Manufacturers provide different procedures for activating and deactivating the mode, so instructions may differ. I hope this helps avoid the need for a service calls in the future and saves you money.
    source is a article from fixya
    SAb -often- is the Sabbeth mode.
    Your use&care manual should have info on reseting the Sabbeth mode.
    thank you sir
    good luck
SOURCE:
I need to learn how to use my oven, because i don't know how to turn it on.i need to bake,so can u tell me how?
You can get the manual for the RGB745 at the GE Appliances support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box. There are several models that start with RGB745.
On most of the Hotpoint ovens for regular baking, press Bake and use the + or - buttons to set the desired oven temperature. Then press Start/On. Then the oven will display Pre as it re-heats. When the thermostat indicates the desired temperature is reached, the oven will beep. The racks should be on the middle positions for most baking. (For roasting use the lowest positions.) Put the food in when the oven is done preheating. When done, press Clear/Off. Timed baked requires the clock be set correctly, then set the start and end times.
For the older ovens with dials to control the oven, set the first dial to Bake and the second to the desired temperature. Wait at least 10 minutes for the oven to preheat. Again put the oven racks in the middle of the oven for most baking.
Do not lock the oven latch and keep the oven closed through the baking cycle as much as possible. (Rotating pans and basting steps should be done quickly so that the oven doesn't cool much.)
I hope this helps.
Feb 11, 2011 | Hotpoint RGB745 Gas Kitchen Range
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 | Ovens
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Maytag MGR5750 Gas Kitchen Range Logo
303 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
