The value of resistor (R331) on hp laserjet series II ?
The resistor is on the circuit board attached to the fuser unit
  • 1,326 Answers
Are you sure it is a Resistor and not a solid state fuse? One way is to look on the outer cover of the resistor. The color of the bands are a color code for ever thing about the resistor.... You had to learn it in electronic school.... Refer to your old books...
Posted on Apr 25, 2010
Does anyone have the schematic of the RM1-4815 which is the low-voltage supplier board. Actually I just want to know the value of the R106. It has burned in my board. Thanks a lot
Hello;
You would be better suited to order a new power supply board such as the one listed below on eBay, as HP does not provide any real support for things such as this and it is probably /maybe a lot cheaper anyhow doing it this way! I know it seems like a waste of money for 1 stinkin' cheap resistor (if that's all it is) but what if the other part it is attached to that caused the burn out is nearly bad also?
NEW HP Color LaserJet CP1215 CP1515n CP1518ni LV Power Supply RM1 4815...
Good Luck!
Rich Lilja
Aug 21, 2015 | HP LaserJet CP1215 Color Printer
HP CP4025N 59 CO EROR
Hi
probably this fuser unit is faulty, the other issue this machine uses the electric current 110 v or 220v
Jun 13, 2014 | HEWLETT-PACKARD 110v Fuser Kit Fuser Unit...
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Apr 28, 2009 | HP LaserJet 2200D Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
HP 2100 LaserJet, was functioning ok, now won't power up, power to AC plug is ok ... Is there a fuse somewhere ? Jim
Remove rear cover and fuser.
Blown fuses usually point to a bad power supply which is the circuit board under the fuser.
Feb 07, 2009 | HP LaserJet 2100 Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
May 30, 2008 | HP LaserJet 8150n Printer
Printer
You need to replace the fuser, here is an example of replacement part
HP Fuser for LaserJet 5000
These are instructions for replacement:
HP laserjet 5000 fuser instructions
Apr 24, 2008 | HP LaserJet 5000 Printer
k24674
