I have a HP C309 all in one printer. trying to get it to fax using magicjack and can't get it. i have a cable internet connection. need ideas.
  • 399 Answers
SOURCE: printer keeps saying usb cable not connected
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Posted on Dec 06, 2008
  • 65 Answers
SOURCE: Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Posted on Jul 29, 2009
  • 414 Answers
SOURCE: does magicjack allow the hp officjet 7410 to send
You should be able to send and receive faxes with the majic jack.
Posted on Nov 02, 2009
SOURCE: HP Premium C309 All-in-One Printer error message "C2FE0065"
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
Posted on Jan 24, 2010
  • 9 Answers
SOURCE: Why does my HP c309 Photosmart Premium printer
The Photo Black is pigment ink (last much longer than dye ink), while the Black is dye ink. Have alook here: http://www.earthboundlight.com/phototips/dye-pigment-metamerism.html
Posted on Apr 15, 2010
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
HP6210 faxing with MagicJack---Any suggestions?
Try using the magic jack on a seperate computer, you are using two lines at once with the fax and the magic on the same machine and it sounds like it's causing a usb problem
May 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have an HP photosmart premium fax C309 series. It is connected to a mac but the scanner function will not work. It gives a preview and then says an unknown error occurred. I tried uninstalling and...
Hello
Based on information you have provided I understand that you have problems with your Printer. I realize the inconvenience it may have caused you. I will provide my best information to get a fix for this issue.
As per my analysis,
Issue : Mac OS : Scanning with HP Scan Software
Printer : HP Photosmart Premium Fax All-in-One - C309a
OS: MAC
The solution for the issue you described is provided in the online HP knowledge-base article Link :
I Cannot Scan on MAC
Setting up and using the Product
Scan Does not start
Thank you,
Cheers
Tejodhar Atreya U
Jan 04, 2010 | HP Office Equipment & Supplies
Using MagicJack with Network ''all in one'' Printer/Fax
MagicJack does not work with all fax machines. If you can find it you must turn off ECM or error correction mode. Also select the slowest transmission speed possible. If you have the manual for it you should be able to find the settings in there.
Oct 17, 2009 | Office Equipment & Supplies
Jul 27, 2009 | HP LaserJet 3050 Printer
Slow down officejet v40 fax transmittion
Magic jack is lying to you. It is a DIGITAL phone service, fax machines are ANALOG
Feb 19, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Setting up fax with modem
try to used the two conductor cable that came with the printer itself.
- at the same time ask for a filter from your phone provider
- the printer should be direclty connected to the phone walljack
- if you have all this kind of set-up you will be able to recieved faxes now..
send comment/feedback fo furthere troubleshooting...
Aug 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Can I connect my HP 3055 to magicjack for faxing
Sure you shouldn't have any trouble doing that. I'd say a magicjack.com would be cheaper than voip since it's 20 a year.
Jul 25, 2008 | HP LaserJet 3055 All-In-One Printer
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
