Question about Whirlpool Dishwashers
I have a GU1500XTLB1, type-575-0 Whirlpool Gold dishwasher. For the last couple of weeks I've been getting the control lock on. I got the manual out, I hold the air dry button and it clears. My problem is now when I turn the machine on dosen't matter which cycle I hit (pots and pans, normal, or quick wash) it runs for about 5 minutes and it goes into a mode with the timer having lines going horizontal with the air dry button lit up and rinse button lit up. It sounds like it starts the cycle but shuts down and freezes in this mode. I've hit cancel three times and it pumps the water down like its suppsoe to. Could I have a problem with door sensor because now when I push the door in there is a fine line I can push it in 2 min.'s will light up and then go away. I can't get the water to pump out. Does it sound like the cycle motor/pump has a problem?
  • 2 more comments
  • Taylorrt2100 Apr 23, 2010
    To clear the control lock I hold the air dry button down for 5 seconds. Right now it will not do anything. I have horrizontal lines on the timer with the rinse only button blinking, air dry button blinkin. I tried and it didn't work but I didn't understand this comment( IF not, look for the lock symbol and follow same instructions for that particular key) Is Hi temp wash and Hi temp scour the same thing
    I know your busy and right I sent the reply the dishwasher came on. Right now its sitting with the water out of the bottom. Do you want me to try it and what mode? Thanks, Rodney !!!
    I tried this and in the middle of typing one response it came on and pumped the water out. I was going to try it again and the same thing is happening. Horrizontal lines on the timer, air dry/ rinse only are flashing. I tried hitting cancel it takes the horrizontal lines off but will do nothing. I tried hitting the buttons in sequence, my question is Hi temp scour the same as hi temp dry
    I've tried pushing every button and every sequence possible. When I said there was water in the bottom, I meant water in the bottom of the dishwater. It pumped it out, there isn't a leak coming out of the machine. Sorry for the confusion, let me know what to try next. Do you work tomorrow or will be answere from somebody else. Thanks, Rodney ~~~
  • 10,515 Answers
There are Few Tricks to Reset this. Follow the below Tricks :-
1. Try holding down heated dry key for 5 secs. I believe that is the control lock/unlock button on your model. IF not, look for the lock symbol and follow same instructions for that particular key.
2. Press the following buttons is sequence, you have 6 seconds to do this reset, hopefully the computer will reset itself and let you wash again.
1. Hi-Temp Wash
2. Air Dry
3. Hi-Temp Wash
4. Air Dry
If Problem still persists let me know and i would search few more tricks and then we could try to Fix this.
This is a Common Error Indication on this Machine and usually, this could be Reset.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 23, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Apr 23, 2010
    Thanks for your response!!
    Have you tried the Second Sequence.
    1. Hi-Temp Wash
    2. Air Dry
    3. Hi-Temp Wash
    4. Air Dry
    This is the Best way to fix this. Try and let me know.
    Note - Forget about that Lock Comment :). As of now, try the above and let me know,if that would reset it Unless we need to Check.
    Do you have any idea, where it is Leaking from ? Any Error Message?
    What is the Sequence of the Blinks?
    Hope i helped you.
    Thanks for using
  • taran_2005
    No, these are Different. However, you could try the Combination. It depends on the Model to Model. I am still Searching the Exact Reset Procedure for your Model.
    Usually ( 85% ), if the Control Lock would not Reset, it is Faulty Control Board. But, as you said, there is a leak from the bottom.So, i am in discussion with other experts on the same and would reply when i would get some data.Kindly bear for the Inconvenience.
    Hope i helped you.
    Thanks for using
  • taran_2005
    I would be available, i am still in discussion with other experts. We are still Discussing. Once i would get some more details, i would Post the same.
    Thanks!!
I have a whirlpool gold dishwasher. The controls locked light is on and I can not get it to shut off. I can not run the dishwasher
In reading the manual, it shows the following:
To turn on Lock, press and hold Control Lock for at least
3seconds.
To turn off Lock, press and hold Control Lock for at least
3seconds.
Jun 07, 2015 | Whirlpool Dishwashers
Whirlpool Gold quiet washplus dishwasher Red Light staying on--control locked Cannot get it to run, no buttons will do anything
Which model dishwasher do you have? The Control Lock is a feature that keeps a child from starting the dishwasher when it shouldn't run. The Cancel button will work but not the Start button.
On the DU920QWD, to toggle the Control Lock off, press and hold Air Dry for 5 or more seconds. (Holding it again will turn on the lock.) Most dishwashers will have a the Control Lock key labeled with text in a small font for how to enable the Lock. The direct link to the DU920QWDB4 manual is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203376817.pdf .
For other Whirlpool dishwashers, the Control Lock sequence will be listed in the manual. You can get a PDF of many Whirlpool appliance manuals from http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . Enter the model number (from the rim inside the unit) and click on the right arrow.
I hope this helps.
Sep 08, 2011 | Whirlpool Dishwashers
Whirlpool Gold dishwasher not cleaning dishes. It runs through the cycles and rinses, but dishes are not completely clean.
I had a similar problem with my last two dishwashers, with food still left on the dishes at the end of the cycle. What a nightmare. The most recent dishwasher is new, now the problem is solved. Here's what the manufacturer told me. Pour white vinegar (approximately 2 cups) into the dishwasher and run through the cycle. Buy some Cascade Complete and only use this type of soap for the dishwasher. Make sure you run a cup or two of the white vinegar through the dishwasher cycle once a week. My dishes are now clean and clear!!
May 26, 2011 | Whirlpool Dishwashers
I have a Whirlpool Gold freezer top refridgerator. Over the last couple of weeks the freezer has built up an awful lot of frost. There is nothing in the troubleshooting part of the manual that addresses...
Most likely a deforst issue, having to do with either the Defrost thermostat or the Defrost timer, given that this unit is not the newer style with the control board instead of the timer. Anymore questions feel free to ask.
Nov 30, 2010 | Whirlpool Refrigerators
Green Lights flashing, Whirlpool D/Washer not responding
Well I contacted a couple of techy guys I know and they were not familiar with the dishwasher. I then called the outlet we had purchased from to see if they could refer us to a service technician. I explained what I wanted and the woman on the phone asked what the problem was - she then asked me to close the door of the dishwasher and hold down the start button for 30-40 seconds to see what happens, which I did. At about the 30 second mark the machine started. She said it was likely that someone had interrupted the last cycle and we had effectively reset it. It ran a further 30 seconds to complete that last part of the interrupted cycle and has been fine ever since. My wife took them a box of chocolates the next day. Shows to go ay? Kind regards Peter
Dec 16, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The Controls Locked button is on and nothing works on my whirlpool gold builtin dishwasher. HELP!!!!!!!!!!!!!!!
Most whirlpools you just hold lock button for a few seconds and it will return to normal function.
Apr 21, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Apr 07, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
141 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
