Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Flashing red light on the display unit
My model is the LC-30HV4E - suddenly lost the picture and now won't power on. I have turned off and checked al connections, when I turn bck on both lights go green for a few seconds and then turn red with the display unit flashing.
  • 5 more comments
  • briscoe11 Mar 25, 2008
    I think it flashes 3 or 4 short and 1 long (sorry not at home at the moment) but only on the monitor.
  • JLKapp Apr 05, 2008
    different model - same problem. Won't turn on, red power light on tv flashes.
  • Anonymous Apr 29, 2008
    Same problem. One day no picture. One long, four short red flashes from the power light on the TV. Sharpe's customer service web site ignores my email. I'll never buy a Sharp product ever again.
  • Anonymous May 13, 2008
    se conectan ambas unidades pero al encenderlas , da la luz roja y luego enciende la verde al cabo de algunos segundos vuelve a tomar la luz roja y enpieza a parpadear y el tv no enciende...
  • brandont Oct 17, 2008
    3 SHORT 1 LONG RED FLASHES ON THE POWER LIGHT PLEASE RESPOND I WANT 2 FIX THIS ASAP AND ITS AN OLD POST
  • Anonymous Dec 23, 2008
    Same thing with a Sharp XL-mp131 Cuts on, then right off again. Flashing light. No technical documentation anywhere... NOT EVEN IN THE MANUAL!!!!!!! What the Heck?
  • jedikn1te May 11, 2010
    What pattern is it flashing? That can tell me what is wrong.
VOTIT
  • 2071 Answers
SOURCE: POWER AND OPC LIGHT BLINKING GREEN
The condition of your TV called power supply overcurrent shutdown that"s why you hear a click. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating . Although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Oct 10, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
SOURCE: LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
Posted on Feb 24, 2011
  • 30 Answers
SOURCE: Go to turn on tv
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Posted on Jul 13, 2011
My sharp aquos LC-60E79U has no picture. Perhaps I have a backlight problem?
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 13, 2016 | SHARP ELECTRONICS DE AQUOS LC-60E79U 60"...
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
My unit (just all of a sudden) will not turn on by
Check the power supply and all the capacitors throughout the unit, i have found that this is normally the case when an item will not power on and is displaying red LEDS. Good Luck.
Nov 15, 2009 | JVC DR-MV1S DVD Recorder/VCR
Flashing red light
If the unit does not even turn on, thats a power issue. You need to contact sharp and let them set u up for repair. I hope you still under warranty.
Nov 28, 2008 | Sharp Aquos LC-32D40U Television
No power..
See posting regarding hiccupping PSU & faulty diode.
Dec 20, 2007 | Samsung DVD-VR320 DVD Recorder/VCR
Won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
106 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
