Question about Lexmark X1190 All-In-One InkJet Printer
MY LEXMARK X1190 DOESN'T PRINT COLOURS - Lexmark X1190 All-In-One InkJet Printer
  • maxemevans Apr 25, 2010
    Thanks Pineworks, but my problem is that I've installed a new colour cartridge and it still doesn't work. I've also re-installed the software (still doesn't print colour) and also cleaned the contacts where the colour cartridge goes. All to no avail. I'm going batty - not that I use colour very often. But the problem is also that my black ink printing is rather poor recently. I fell that the only solution will be to buy a new printer and that's a pity as this one scans, copies, does the whole hog.
  • 4,041 Answers
Hi There
You can try this may help you.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
5 Suggested Answers
SOURCE: my lexmark x1270 will not print in black
lexmark x1270 wont work with vista
Posted on Mar 08, 2008
htechie
  • 146 Answers
SOURCE: X1190 OSX driver
Enjoy...
http://driverscollection.com/?file_cid=24627854181MQ9xSRfBqjFo36pP
Please Rate if you found the above info useful. And please comment if you got what you wanted.
Posted on Aug 26, 2009
  • 355 Answers
SOURCE: Driver Lexmark X1190 for MacOS 10.6?
find your driver from these site
1) www.driversdown.com/drivers_abc/abc_L.shtml
2) www.commentcamarche.net/guide/379788-lexmark-x1190
3) www.dealtime.com/xPO-Lexmark-LEXMARK-X9350
Posted on Oct 07, 2009
don_farr
  • 1018 Answers
SOURCE: lexmark x1190 new cartridges but cannot print in
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Posted on Nov 30, 2009
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
Jul 24, 2012 | Lexmark X1190 All-In-One InkJet Printer
When i try to uninstall my lexmark x1190 it comes up printing not finished
Try to clear the Lexmark print queue from pending/stuck print jobs so you can successfully uninstall the Lexmark software/ printer driver. Here's how:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
After successfully clearing the print queue, uninstall the printer software by going to Start menu > Programs > Lexmark 1100 Series folder > Tools > Uninstall. Reboot your pc when prompted.
Hope this helps.
Apr 30, 2012 | Lexmark X1190 All-In-One InkJet Printer
When printing, the blue color is missing
Make sure your print cartridges have enough ink in them for printing.
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to fix the problem:
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working color cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X1190 All-In-One InkJet Printer
Need to find a way to get my lexmark X1190 printer to be compatible with macbook OSX Lion
I regret to inform you that the Lexmark X1190 printer is not compatible with Mac OSX Lion. Please contact Lexmark Technical Support Center for other options.
Aug 23, 2011 | Lexmark X1190 All-In-One InkJet Printer
Lexmark X1190, comment remettre à zero le
les impriments lexmark ne sont pas equipees d un compteur, le comptage se fait avec une formule mathematique programmee dans la logique de controle, tu peut remettre a zero en installant de nouveau le driver.
Dec 02, 2010 | Lexmark X1190 All-In-One InkJet Printer
I've installed Microsoft Windows 7 and and now I can't install my Lexmark X1190. What ca I do?
Unplug the Lexmark printer from your computer. Uninstall any existing Lexmark X1190 driver from your computer by going to the Start menu ? Programs ? Lexmark X1100 Series ? Tools ? Uninstall. Reboot pc when prompted.
When your computer turns on, check the System Type if it's 32-bit or 64-bit by going to the Start menu ? right-click on Computer ? Properties. Take note of the System Type.
Use Vista driver in Windows 7. Click on the links below to download the Lexmark X1190 from the Lexmark website.
Download, execute the file and follow the instructions in the software. Thanks.
Nov 21, 2010 | Lexmark X1190 All-In-One InkJet Printer
I have lexmark x1190 printer and but dont have the cd for the software please assist me to download the software
http://www.downloadsource.net/12502/Lexmark-Printer-X1110-X1130-X1140-X1150-X1155-X1160-X1170-X1180-X1185-X1190-X1195-Driver-Windows-2000-XP-32-bit-2003-32-bit/
Aug 13, 2010 | Lexmark X1190 All-In-One InkJet Printer
Lexmark X1190 cartridge hits extreme left side & no print
take the print cartridges out , switch off ur printer. wait 5 min. switch it off again. and put cartridge back again.
Apr 24, 2009 | Lexmark X1195 All-In-One Printer
Lexmark X1190 All-In-One InkJet Printer Logo
290 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
