Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
I seem to be experiencing an electronic sensor problem with my Impressa S-9 one touch unit. Last October I returned my unit because of the same difficulty, a replacement (not new) arrived in November last year. Now, 6mos. later and the problem has returned. There is a "male, female" sensor interlock, the male portion located on the back of the removable tray and the female portion located in the frame of the unit. If I play with it, I can get the interlock to work for a short period of time and then it reverts to it's message to either "empty tray" (which is already empty) or indicates that the tray is missing. It is a nanosecond trip over from one message to the other, with the "coffee ready" being between the two messages. I live in Belize in a VERY high humidity situation and it costs a dear price to send the unit back to the states for repair. Looking for suggestions!
  • Jura Capresso Master
  • 1,711 Answers
From what I understand you have already realised that you need to replace the tray sensor but it is not easy and will cost you much.
So you can make a trick to your machine as follows.
If you can remove the side panel where you can find the the sensor on the body of the machine and you will see that the sensor have two wires on it. These wires are suposed to be connected together when the other part of the sensor located on the tray is insert, indicating that the tray is back on its place. Is like an on off switch.
So you can remove the sensor from the body of the machine and use the hole on the body in order to conect additional wires to come out from the machines. All you have to do now is to conect the two wires together manual. Every time you remove the tray to empty it you have to desconect the wires for some second and then conect them back together.
So now you will give the signal that the tray is out and them back in place by yourself and not automatic.
Then you can even try to find the sensor switch from internet and relace it your self so that the machine will work again automatic.
Posted on Apr 23, 2010
How can I fix my Jura Impressa z5? I have an error 4 on the display of my Jura Impressa Z5 coffee machine and other than turning it off at the power it won't do a thing.
Error 4 is in Plain text a Temperature measurement error in steam cycle (circuit)
Causes / Remedy:
Sorted in order of likeliness !!!
1) Thermal sensor is defective. Determine the resistance value at 20 degrees C to be about 12kOhm. - Replace thermal sensor if not.
OR
2) Cable broken to the thermal sensor or oxidized contacts. - Replace / repair the cable.
OR
3) Logic board defective - replace electronics / replace EEPROM.
If you want to do the job yourself. Parts for repair solutions above are
1) Replacement Thermal Sensor with cable GBP 19.99 plus postage
2) if you can fix broken wire or oxidized contact no need for parts
3) logic board GBP 198.99 plus postage (there might be the possibility to have EEPROM on the board replaced at a fraction of the price. Defective board must be sent in first.
It also is possible to sent in the machine for repair.
Jun 11, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Tip
Mack Fault Codes List
FAULT CODE IDENTIFICATION TABLE - VMACIII - 1998 & NEWER
1-1 Engine Oil Pressure Sensor
1-2 Barometric Pressure Sensor
1-3 Fuel Temperature Sensor
1-4 Ambient Air Temp Sensor
1-6 Starter Input
1-7 Engine Coolant Level
1-8 (ASET CEGR) Estimated % Fan Speed
1-10 Aux. Cooling Relay Output
2-1 Engine Coolant Temp Sensor
2-2 (ASET IEGR) Boost Air Pressure Sensor
2-2 (ASET CEGR) Boost Air Pressure
2-3 Intake Air Temp Sensor
2-4 Trans Oil Temp Sensor
2-5 Front Drive Axle Oil Temp Sensor
2-6 Rear Drive Axle Oil Temp Sensor
2-7 Engine Oil Temp Sensor
2-8 (ASET CEGR) Combustion Air Temperature
2-9 (ASET CEGR) Combustion Air Temp Sensor
3-1 Exhaust Temperature Sensor
3-2 Engine Speed Sensor
3-3 Redundant Engine Speed
3-4 Engine Position Sensor
3-5 Engine Brake Output #1
3-6 Engine Brake Output #2
3-8 Trans Splitter Position
3-10 (ASET CEGR) Engine Brake Output #3
4-1 Vehicle Speed Sensor (VSS)
4-2 Fan Clutch Output
4-3 Auxiliary Output #1
4-4 Auxiliary Output #2
4-5 (ASET IEGR) Wastegate Output
4-5 (ASET CEGR) VTG Position Sensor
4-6 Tachometer Output
4-7 Speedometer Output
4-8 Customer Defined Statement
4-9 (ASET CEGR) EGR Valve Mechanism
5-1 Throttle Position Sensor
5-2 Throttle Position Sensor Reference Voltage
5-3 Engine Shutdown Lamp/Alarm
5-5 Electronic Malfunction Lamp
5-6 Spare Relay #3
5-7 Engine Oil Level
5-8 (ASET CEGR) EGR Temperature
5-9 (ASET CEGR) EGR Mass Flow
6-1 Fuel Level
6-2 (ASET CEGR) Turbocharger Speed
6-3 J1708/J1587 Link
6-4 J1939 Link
6-5 All Communication Lost - Engine Shutdown
6-6 Fuel Control Module
6-7 Power Relay
6-8 J1939 Link
6-9 Other ECU Affecting Operation
7-1 Service Brake Switch
7-2 Parking Brake Switch
7-3 Speed Control SET Switch
7-4 Speed Control RESUME Switch
7-5 Battery / Alternator Voltage
7-6 Switched Voltage
7-7 Exhaust Temp Reference
7-9 VTG Actuator
8-1 Electronic Unit Pump #1
8-2 Electronic Unit Pump #2
8-3 Electronic Unit Pump #3
8-4 Electronic Unit Pump #4
8-5 Electronic Unit Pump #5
8-6 Electronic Unit Pump #6
8-9 Solenoid Boost Voltage
9-1 Transport Protocol
9-2 Power Reset Without Key Switch
9-3 (ASET CEGR) Aftercooler Outlet Temperature
9-5 (ASET CEGR) Compressor Discharge Temp
9-8 (ASET CEGR) Auxiliary Output Device #1
9-9 (ASET CEGR) Auxiliary Output Device #2
9-10 (ASET CEGR) Auxiliary Output Device #3
10-1 (ASET CEGR) Internal Sensor Voltage
10-2 (ASET CEGR) 5 Bolt Supply
10-3 (ASET CEGR) Sensor Supply Voltage #1
10-4 (ASET CEGR) Sensor Supply Voltage #2
10-5 (ASET CEGR) Fuel Filter Differential Pressure
10-6 (ASET CEGR) Fuel Delivery Pressure
10-7 (ASET CEGR) Odometer Save Area Failure
10-8 (ASET CEGR) GPS Position Data Not Received
10-9 (ASET CEGR) Watchdog Timer Reset
source
on Dec 20, 2016 | Cars & Trucks
Tip
Fault Codes Kitchen Aid cooktop
F03 One or more eyes permanently pressed. Recommend that the glas be cleaned and all objects removed.<br /> Unplug the unit for one minute the plug back in if the error still remains after returning power then you will need to replace the touch control module.<br /> <br /> F12 Electronic board and touch module communication error.Unplug the unit for a couple of minutes.Restore the power if the error return then you will need to replace the board connection cable between the touch control module and electronic control. if the error remains replac ethe electronic control board. If the error comes back again replace the the touch pad.<br /> <br /> F13 Internal CPU checksum error.Recommend you replace the touch control module.<br /> <br /> F22 Key sensitivity problem.Turn power off to unit for a few minutes,if the error returns after power is restored replace the touch control module<br /> <br /> F36 Temperature probe hardware error.Recommend that you replace the touch control module.
on Jan 02, 2011 | KitchenAid 36 in. KECC568 Electric Cooktop
Jura impressa s9 is displaying error 1
The Owner Manual for the Jura Impressa S9 One Touch identifies Error 2 as being too cold and disabled for safety, but simply instructs to "Turn the IMPRESSA off at the power switch. Contact Customer Support in your country." for all other errors.
See Online Manual: http://content.costco.com/images/Content/Misc/PDF/OwnerManual-671992.pdf
Apr 29, 2013 | Jura Impressa S9 One Touch
My Jura Capresso F9 keeps making coffee when no one is pushing the buttons. It is always a big cup, mild. Any ideas what could cause this, other than a ghost who likes weak coffee, as my 5-year-old...
Apparently after a few yrs of use the steam wafting up from a cup of coffee works its way into the electronics touch screen mechanism causing it to turn on by itself...since moisture is such a good conductor for electricity it seems like there is a "ghost in the machine"...credit "The Police" band for that quote...my simple solution was a 6-7 dollar desk fan purchased from Walmart and point it up across the front of the unit...problem solved!...just keep the fan running while you use the unit and save a bundle of $$ not having to send it back to Jura!...Bob in SC
Sep 24, 2011 | Jura Capresso Impressa F9 Espresso Machine
F1-8 error
F1 indicates a clock or touch pad problem. F8 indicates a clock, or ERC (Electronic Range Control) problem. Are you receiving both codes? If so it seems likely that your touch pad and ERC are contained together in one module, and must be replaced. If you find however that they are separate modules it is possible to determine which is faulty by simply disconnecting power to the unit, disconnecting the touch pad from the ERC, and then powering it back up. Wait for a half hour or so to see if the unit sets the error code again with the touch pad disconnected. If it does the ERC is faulty, otherwise it is the touch pad.
Please note that if you do not have experience mucking about in your appliances inner workings it is best that this be done by an experienced technician.
May 12, 2011 | Jenn-Air Cooktops
No color when turned on, after a while it color returns.
This is a cold solder joint in the signal section of the set. After it heats up, that problem area conducts better. Have an experienced electronic person reflow some solder on the board.
Feb 02, 2009 | Toshiba 32AF43 32" TV
Kenmore HE3 seems to use way more than 10.5 gallons
well the water is meter by the unit ,,but i can give you the read outs,,large loads 12 - 14 gallons..medium loads 10 -11 1/2 gallons small loads 9..these are tech estim...it depend on clothing being wash,,,good luck onthejob
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
The car would just stall for no apparent reason
Finaly had to replace the ignition swich on my S10 Blazer, that solved my problem , that was after Circuit City said they had no idea what the problem was, they worked on it every week , until I figured what was wrong with it.
Dec 23, 2008 | Viper Security and Remote Start System...
Impressa Z5 Error 8
We have just done a full disassembly, cleaning, and relube of our Jura Z5 Impressa unit. Here are the full details of the RainyDayProject:
http://www.rainydaymagazine.com/RDM2009/Home/October/Week4/RDMHomeOct2009.htm#JuraZ5BrewUnitCleaning
Click on any of the images for larger version.
Sincerely,
RainyDayInterns
May 04, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
83 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
