Question about RCA OPAL M4001 MP3 Player
Reset to default to start all over again
If i want to delete all the music in my mp3, how can i reset it to default to start all over again?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 25, 2008
My eclipse forze, what can I do?
First, try pulling the battery out and putting it back in, then turning it on. If that doesn't help, try and reset it to its defaults using a small button that you have to push with a pencil led or other thin, circular object. If you can't find such a button, plug the MP3 player into your computer and format it (WARNING: all music on there will be deleted, so back it up first), then try starting it up.
Mar 01, 2011 | Eclipse CLD2 MP3 Player
Format e200
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
May 24, 2010 | SanDisk Sansa e260 MP3 Player
Can u help me to deleting everything on my MP3 player. All the files r corrupt. Doesn't allow me to delete or add music. Has these stange language or symbols that arn't deletable? Is there a way to reset...
Hi, follow the instructions below to reset your Nextar mp3 player
To customize the player settings:
(1) On the main menu, select the “Settings”item and press the MENU button to enter the
system settings mode.
(2) Press the PREVIOUS/NEXT button to select setting item and press the MENU button to
confirm or press the PLAY/PAUSE button to cancel/return.
(3) System
(4) Load Default - Restore the player to default setting
Take care
Feb 18, 2010 | Nextar MA797-20 MP3 Player
My Philips SA52xx GoGear MP4 Player won't start up. It just starts starting up and freezes on GoGear, it also makes wierd crackling sounds when playing music... My Philips GoGear used to start up within 10...
if it has too many songs on it try deleting some of the songs off the player, and if thats not the case, stop using it for a few days then try to turn it on again
May 31, 2009 | Philips SA3125\02 MP3 Player
Under settings accidently set to default & it took out all of my music. how can i get my music back, restore my music?
If you have an Ipod, you are gonna need a lot of time. It will take long to sync each one seperately. If it's just an mp3 player, do this:
1.Open up your music folder and copy ALL your music. Do NOT delete it all.
2.Go to MY COMPUTER>then your mp3 device. Click paste. Your mp3 light might flash if you have one - this means it's sending it to your mp3.
3.You will get a box come up on the screen telling you it's copying the music.
4.There you go. Your music is on your mp3 again.
-sigh- if only ipods were so easy
May 27, 2009 | Audio Players & Recorders
Deleting music from a mp3 player
  Simply connect your MP3 player with your PC open the songs folder delet the songs which no more needed and copy new songs from your pc and paste it on your MP3 player songs folder.And now your Mp3 player is ready to rock.
Thanks for using FIXYA.
Feb 01, 2009 | Samsung Audio Players & Recorders
Help!!!!! My philips SA3125/02 isnt working!
Reset will NOT delete all your music, but the permanent fix that you need to prevent this from happening again will delete all the songs. Reset, and see if it works. But it might freeze up on you during vacation. You will have to keep pushing reset until you get home and have more time for the permanent fix.
Jun 10, 2008 | Philips SA3125\02 MP3 Player
My music folder is gone
To reset the player hold in the power button for at least 20 seconds, when you release the button the player should restart on it's own. If it does not then try again holding the power button for a little longer. If for some reason the player becomes unstable and resetting doesn?t resolve the issue, then try the Sansa Connect Recovery Tool which will clean up your player and restore it to factory settings. You can download this tool & get instructions on it's use on the following link: http://www.sandisk.com/Retail/Default.aspx?CatID=1532 Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | SanDisk Sansa e250 MP3 Player
File error
Try a reset and see if it corrects itself. hit menu, settings, scroll to reset all, select yes. This won't delete any files, but it should clear up the song transfer problem. If that doesn't work you may have to reformat the device which will erase all data on it. But then you can start fresh again.
Jul 31, 2007 | SanDisk Sansa e250 MP3 Player
Sansa m230 cannot see previously installed music files now that WMP11 is installed
I had the same problem on my m230. The final solution that worked for me was to disconnect then go into settings;usb and set it to MSC. Once I re-connected I could see everything.
Feb 06, 2007 | SanDisk Sansa m230 MP3 Player
RCA OPAL M4001 MP3 Player Logo
24 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
