Question about Refrigerators
Gsl25jfxlb GE Fridge suddenly stopped working, lights on, no compressor noise, condenser fan not coming on. Any ideas? Possibly how to test if that fan works because the condenser was extremely dirty, lots of dust.
  • Jonathan Crappel Apr 23, 2010
    I really think it may be the condenser fan, do you know how I could test this?
  • Jonathan Crappel Apr 26, 2010
    OK, so I finally figured this problem out, with help from SeaBreeze, much thanks to him. Turns out that for some reason this refrigerator turned itself off. The button that are by the ice dispenser are the ones I used to turn it back on. They are the temperature control buttons, I pressed them and voila! It came right on. We're not sure what caused it to shut off so, I am keeping an eye on it. Fingers crossed. Thanks SB.
  • 17,970 Answers
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these: - Wiring - Thermostat - Defrost timer - Compressor - Overload and/or relay
Unfortunately, we can't describe all of the possible problems and repair solutions here. If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician.
The whole fridge just isn’t as cold as it should be or it’s warming up.
  • It ain’t plugged in…duh!
  • No voltage at the outlet. Go ahead and check the simple things first. And make sure that circuit breaker ain’t tripped.
  • Load of **** on the condenser coil. Pull the bottom grill off and get down on your hands and knees to look. And, Hoss, use a flashlight and a condenser brush if you need to clean the condenser.
  • The condenser fan motor (the one underneath) is fried. If it’s not running, replace it even if it starts running when you start it off by hand. Oh, you may think you fixed it if you get it started again but, believe me, it’ll **** out on you again real soon.
  • You should still check the stuff listed in the previous problem ’cause you might be in the early stages of defrost system failure and it just hasn’t gotten that bad…YET.
  • The cold control is open (that’s "thermostat" for those of you in Palm Beach). I like to jumper out the two wires on the cold control contacts. I don’t know what you like to do but you’re liable to get your gluteous flabeous shocked if you’re not careful doing this.
  • The compressor ain’t starting. This is the dreaded "hummm…CLICK" sometimes heard when a compressor can’t start. There are several things to check if this is the case:
  • The compressor start relay could be fried. The newer solid state relays are especially bad for this.
  • One of the compressor motor windings is opened up. How do we check open circuits, boys and girls? That’s right, we use our ohm meter. These should measure on the order of single digit ohms. The start winding should have slightly higher resistance than the run winding.
  • Current leakage from compressor motor winding to ground. You need to use a special instrument called a megohmmeter.
  • Procedure for checking the compressor.
  • You sprang a freon leak or you got an iceplug in the cap tube. Go shopping.
  • The light could be staying on in the compartment. You’ll need to check and replace that light switch.
  • Someone (kids usually) left the door ajar. "Oh no, I never do that." Yeah right, Bubba, I’ve heard it all before
Hope help with this.
Posted on Apr 23, 2010
My GE Profile Refrigerator (model PDS20MBSBB) is making a clicking noise. The thermostat display turns off while this happens. When it comes back on the fridge gets really cold and then slowly gets
needs new control board wr55x10942. condensing fan not running or running slow. it get to hot then the compressor relay cut off compressor to protect it once cooled down enough it starts back running.
Oct 09, 2014 | GE Refrigerators
Model gss25lgmb ww
If the compressor is not making any noise and a fridge is worm it means that the compressor is not working. It could be a faulty compressor or a control unit. If it is a compressor, it is not that simple to replace it yourself, unless you have a proper equipment. Because the unit has to be evacuated and recharged with a refrigerant after replacement.
If it is a control unit, it can be replaced, but I would leave it up to a pro to check it out and fix it, if it is worse.
Jan 29, 2014 | GE Refrigerators
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
I have a GE Profile French door. Mod pfs22sisbss. It is not cooling enough to keep the programed temp for the fridge or the freezer. I tried using the turbo feature and I can hear a clicking sound and then...
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help in solving the problem....
Feb 03, 2011 | GE Refrigerators
I have a side by side fridge that quit cooling (freezer and fridge) yesterday. the compressor is hot on the top and sounds like it is running. i turned it off for 24 hours to see if it was possibly frozen....
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 16, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Ge tfx 22krdavw refrigerator not cooling
Step 1 – Find the Problem
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
Step 3 – Find the Timer
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
Hope this helpout.....
Aug 08, 2010 | GE Refrigerators
GE side by side unit. Freezer OK, fridge
Step 4 – Volt Test
Hope this work.....
Jul 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GSS25KGMB CC side by side GE fridge not cool.
You should check first to see if the condenser coil is dirty ( condenser coil is the Fin type coil you see in front of the compressor ) You can clean this by just brushing it out with a brush .The relay is plugged directly onto the compressor
May 17, 2017 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
GE - SIDE BY SIDE MODEL TFX25JR - Continous HUM
Probably the condenser fan motor is going out they will often make noise for a long time before anyone notices. Get it looked at soon. overheating the compressor on that old of a fridge could spell trouble.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
