Question about Music
Diagram fr audio 2 usb cable means data &charging both in one fr shuffle apple ipod
  • Music Master
  • 5,603 Answers
Yes, the charging is done via the 5 volts supplied on the USB cable.
Google this: ipod shuffle usb cable diagram
That will bring up the diagram!
Posted on Apr 23, 2010
Ground issues
Rule #1: All interconnected devices... amps, speakers, etc... SHALL be powered from a single receptacle OR power conditioning module.
Rule #2: All interconnecting audio cables SHALL be balanced, either XLR or TRS.
Rule #1 means running extension cord for power alongside a snake for instance.
Sep 06, 2011 | Allen & Heath Allen&Heath PA12-CP
I have an M-Audio Keystation 61es. Lately I've had random loss of power through the USB2.0 cable. The cable still powers my other M-Audio products, so the issue is the Keystation. It is possible...
I have the 88 key ones and powering via the USB is marginal... IF you have a place for an adapter, use one, as the computer USB is limited to 1/2 amp and OFTEN they limit at a little less and then the keystation is not reliable...
Aug 30, 2011 | M-Audio Keystation 61es USB MIDI...
Hi i have connected all the cables up correctly & have it all working except i have some sort of interferance coming through.i have a contant crackling & on & off buzzing sound,sound like...
First thing: Make sure ALL and I do mean ALL of your interconnected equipment is POWERED from the SAME receptacle. Powering different parts from different receptacles in a building will surely get ground bounce buzz and ALSO subject the equipment to hazards of circuit damage.
The audio connecting cables should be BALANCED lines where possible... either XLR or TRS cables. Problems like you are having are common when CONSUMER grade equipment is mixed with PROFESSIONAL equipment. Anyway, get all the stuff powered from the same receptacle and get back to me if you still have the problem. Note you may have to run three wire extension cords if devices are separated a bit... the pro's have to do that to avoid noise. All devices should have three wire (grounding) cords and/or grounding wires connecting chassis...
Jul 16, 2011 | Mixvibes U-Mix 44 4-in 4-out USB Audio...
How do I connect an ipod to my EPA900 ? also, I have a digital recorder with a USB connect. Is there a converter product that I can purchase that will allow me to connect this recorder to the system?
It is unlikely to find a compatible USB convertor for that digital recorder. If it has audio input you can probably use a similar cable to that for the IPOD described next. For the IPOD, get a 1/8 inch STEREO splitter cable that splits to 1/4 inch plugs or RCA plugs to connect to the PA system. Radio Shack will probably have a suitable one.
Jul 15, 2011 | Behringer Europort EPA900 Ultra compact...
When I connect my Privia PX-130 to my computer (and Logic) it works perfectly but if I connect the audio out (via line out) at the same time, the audio sounds dreadful, even if I'm not going through the...
I SUSPECT that the USB connection is ECHOING the data, causing multiple generators to be active. Those extra ones then are mixed into the line out of the keyboard. In your PC, make sure the echo setting is turned off, OR disable the sending out of audio via the USB. Alternatively, DISABLE MIDI/USB incoming to the keyboard.
Jan 21, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
1) how to make my amp record....because its not working when i try... 2) do i have to a cord in line 1 and 2??? 3) do i have to plug in the cord in :.....line in or line out??????
You will use microphone with balanced XLR connector into the XLR mic input. Note, the ALpha does NOT have phantom power so you cannot use condenser mics.
A guitar can be plugged into the hi-z instrument 1/4 inch jack on the left front of the unit.
To use the line 1/4 inch inputs you will use BALANCED TRS 1/4 inch cables from your source.for these channels. The level on these needs to be line level.
The line outs are for sending audio out to an amp. There appears to be RCA outputs you can use as well.
I am not sure what you mean by making your "amp record"... An amp PLAYS the audio, usually into a speaker.
If you are trying to play a guitar through your amp AND record, then you will connect your guitar to the Alpha, the amp input will have a cable from say Line 1 OUTPUT and when recording wou will have the echo feature on so your guitar is passed through to the amp.
Jan 09, 2011 | Lexicon Alpha Personal Recording Studio
I was trying to hook up our 1604 vlz3 at our church and was wondering how the best way to do this?
Without knowing the resources you are connecting I cannot give you a schematic but will give this GENERAL advice:
1. Use BALANCED lines to connect from the mixer to your amps, preferably XLR connections.
2. Service the power to the amps and the mixer from the SAME place even if it means stringing a power cable alongside you audio cable snake.
Jun 12, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I have no cable for my Roland E-86. Witch one sould i buy??? tank you.
If you mean power adapter, it is a 12 volt 2 amp one and I don't know which polarity.
Here is an Ebay seller that has them for the E86:
http://cgi.ebay.com/AC-power-adapter-4-Roland-E-86-E86-Keyboard-Synthesizer-/110432738764?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item19b64dddcc
If it is the audio cable you are after, just get a standard INSTRUMENT cable (not speaker cable) with 1/4 inch plugs.
May 30, 2010 | Music
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 | Casio Music
Music Logo
183 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
