Question about HP Officejet 7210 All-In-One InkJet Printer
How do I get rid of black smudges and smears when printing. Have cleaned ink nozzles, cartridges and the problem seems to worsen
  • 1,218 Answers
A printer will smudge ink when the printer heads are dirty. To resolve this, you need to take out the printer cartridges and clean off the dirt by rubbing alcohol on the printer head using a Q-tip.
Posted on Oct 08, 2010
  • 52 Answers
Check under the cartridge holder. Sometimes fluff causes a ink buildup ink catridge and the cartridge holder. Clean under the cartridges and the cartridge holder
Good luck
Posted on Apr 24, 2010
What is wrong with my Epson R280 printer when the ink appears smeared down columns of a spreadheet
Probably dirty heads on the nozzle. In most inkjets there is a maintenance option to clean the heads. I would first clean the heads, and then make sure that the print heads were aligned. If that is all squared away then check for any driver or firmware updates. Finally get some rubbing alcohol and gently clean the print head. Sometimes if the printer is not used that often the ink will congeal and smear.
Oct 19, 2014 | Epson Stylus Photo R280 Series
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
Black ink will not print but colors do
Most likely culprit is a dried up ink within the nozzles themselves. The best things for getting rid of dried ink in the nozzles is to use either a standard bathroom cleaner or rubbing alcohol. With the printer on open the door as if you were replacing ink. With the ink cartidges visable, unplug the printer so they stay put. Remove the cartridge and spray the cleaner in the where the ink is taking from the cartridge and clean it with whatever works. I really really good trick is if you have an old cartridge you can use a syringe to fill up the empty cartridge with your cleaning solution or rubbing alcohol. Insert the cartridge and run some test prints. This will for sure run the cleaner through the nozzle and hopefully dissolve the blockage.
Nov 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
I just replaced my black ink cartridge, but when I print a document, it doesn't print some lines. They look faded or smeared
Check the little nozzles on the cartridge. Clean it with a cloth dampened with water. Watch out, though, because the ink doesn't wash off your hands. Use gloves if you have them.
Jan 14, 2011 | Lexmark C533DN InkJet Printer
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Print is Smudged
you may try
1) clean the cartridge nozzles with dry soft paper
2) clean the cartridge carriage down side surface there might be bled ink.
3) check the cartridge up side there is the lable cover the ink refill hole is ok, no any lable stick there you need put stick lable there.
Nov 12, 2008 | HP PSC 1600 InkJet Printer
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
437 people viewed this question
Seeker5211
Seeker5211
