Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheem water heater Lp won't turn on
I have replace the water hearter control valve, a new one under warranty. I initially get a pilot light to burn, no leaks that i can see. Leak check everything, no leak on the pilot light that i can see. I turn the knob to on and it lights but doesn't stay lite. I have also replace the thermocouple. Now I orginially thought it was the control valve, but when exchanged it did the very same thing.
I am wondering being Lp would the line pressure effect control vavle, would it cause the valve to shut down. Thanks Johnny Fife
  • 455 Answers
Hello,I suspect the LP regulator/ diaphram at the supply tank is defective.Sounds like fuel supply problem/pressure.You did everything right that all that is left!
Posted on Apr 23, 2010
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
Believe I need to buy a Rheem Water Heater Thermocouple. Where do I find them?
If thermocouple is from ordinary tank-type water heater, then it is a generic part with different lengths 15" 17" 21" 24" 30" available at hardware of home center.
I suggest reading manual for installation information, advisories, and required maintenance.
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
There are good utube videos on replacing thermocouple.
Tip of thermocouple has to be positioned in the pilot flame.
The heat on tip of thermocouple causes millivolts of electric current that travel back to the gas control valve and the electrical signal causes gas control valve to keep gas flowing down the pilot tube to the pilot light.
If pilot light blows out or if pilot tube is clogged and needs to be cleaned, or if gas valve has gone bad, then tip of thermocouple cools down and electric signal back to gas control valve causes gas control valve to shut off gas going to pilot.
When attaching thermocouple to gas control valve, it is finger tightened.
Be careful and do not cross-thread thermocouple. Just use your fingers to start the nut.
Finger-tighten thermocouple and then add 1/4 turn using small wrench.
The end of thermocouple has a small piece of insulation that isolates the electric current from body of gas control valve. If thermocouple is overtightened, the insulation is crushed, and electrical current millivolts short out and no signal reaches gas control valve, so gas control valve keeps gas turned off to pilot tube.
If this is a tankless water heater, then open following link with troubleshooting resources and contact information for Rheem.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 20, 2011 | Rheem 36" Water Heater Thermocouple Kit
I have a Rheem PG50T9A gas hot water heater. We had hot water this morning. When I came home the pilot light was out and won't stay lit. Any ideas?
Hopefully just the thermocouple. The thermocouple is the small rod right next to the pilot light. The flame on the pilot heats up the thermocouple and keeps the gas valve on. You can replace it yourself. The thermocouple will be connect by a small nut on the underneath side of the valve, and you will have to pull the thermocouple out of the pilot assembly. Not an expensive part, you can get it at any hardware store. Hope this helps you .
Apr 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I can't get my pilot light turned on. I have a Rheem powervent water heater and I can't turn it on. I keep getting an error message that says "FVD interface failure/miswiring". What do I have to do to...
Most likely your flame sensor wiring is partially burn't or has an open circuit fault that's giving you the error message. This wire starts at the gas control and ends next to the pilot assembly. It can easily be replaced using a small wrench to unscrew the end connector from the control and the flame sensor rod at the pilot assembly. Call Rheem and see if the water heater is still under warranty, but even if it isn't they can most likely order the part you need for you. The phone # is on one of the data decals on the side of the water heater tank. They will need the model # and serial # to order the part. Be sure you unplug the unit before working on it! Douglas
Sep 28, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
How do I light my Rheem water heater if my peizo ignitor switch isn't working
Remove the burner access cover under the control valve. Press the pilot light button (gas control) and hold it down. At the same time, light the pilot. Continue to hold the lighting button for a few seconds until the thermocouple heats up. Release the button. Twist the gas control knob to the ON position, and the burner should fire up after a few seconds. Replace the access cover. Good luck.
Feb 09, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light won`t stay burning on my hot water tank. I replaced the thermacoupler;no difference. It is a Rheem Gauardian system ''Fury''. 40 gal in a wellsite skid trailer. Thanks
The thermocouple is a screw in type or 2 wire. You can check the dc MILI volt output with a multimeter. It should probably make 500-750miliVDC when heated. Be sure no plastic from the thermocouple wrapper was on the threads, will not work like that. To light did you push and hold the valve for 30 sec after lighting the pilot then turn to run after the pilot was burning? There is a slight chance the gas valve is bad but not likely. Check the wireing on the thermocouple to the gas valve.
Oct 19, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
40 gal lp locked out at gas control valve. what are steps to unlocking valve?
Try turning the off pilot on knob to off and then turnign the temperature dial to the coldest position. then turn to pilot, relight and see if that works.
Jul 12, 2009 | Rheem Water Heaters
Lp waterheater won't stay burning
check the pressure comming into the burner thru the gas valve, it has to have at keast 2,bs if not you might have to change the regulator
Jun 25, 2009 | Rheem 40 GAL Propane Water Heater 6YR...
Can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Jun 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
98 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
