Question about Kitchen Ranges
Smoke from top of stove
The stove was used at various times today with no problems. Just about two hours agor it was used and smoke bellowed out of it. After clearing the smoke I looked at the bottom and saw only a little burnt material. The burnt material was cleaned as best as possible with kithen cleaner. The stove was turned on again with smoke coming out. A closer look showed that the smoke was not from the burnt material, but from the underside of the plate where the stove top burners sit. Does this mean the stove heater element is having problems?
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
No it means that what ever spilled on the elemnet drip pan has not completely burnt itself off. replace the drip pan at first chance you get
Posted on Mar 23, 2008
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
I replace a ignitor on my stove to a new one but it smoke why
Not Enough Information. If an electrical box smokes obviously that means the electronics are severely damaged. We stock dozens of ignition assemblies and they do not smoke. Are you referring to the grill smoking? An electrical box cannot smoke unless it is fried or is on fire. If the stove is smoking you need to clean it and/or burn it off. smoke is caused by grease.
Nov 07, 2013 | Grilling
I have an 81 kawasaki ke 125. I was riding the other day for about an hour and it suddenly started to backfire and billow white smoke. When it started to backfire it lost a lot of power. It will also not...
Could be that you have blown the piston rings, firstly i would remove the rear silencer, as 2 strokes bellow out exsess smoke and loose power when the silencer becomes blocked due to carbon, start and run the bike and check without the silencer, furthermore to eliminate the exhaust itself is blocked, undo it from the cylinde
Jul 31, 2011 | 1981 kawasaki KE 125
Stove fire smoke on microwave above stove.what will clean off this smoke residue? we encountered a stove which left a heavy smoke residue on the microwave above. the microwave has a plastic handle and...
Mr. Muscle Kitchen cleaner will remove the smoke. It won't hurt the plastic. Just make sure to either wear rubber gloves or wash your hands soon after cleaning off the smoke residue. It will make the skin on your hands / fingers slick and then dry after your done. Let the cleaner sit for about a minute before trying to wipe off the smoke residue.
Mar 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Jul 31, 2009 | Ovens
White smoke from one tail pipe
As u know - that smoke is oil . can be cause by restricted breather or oil filter, worn valve guide or seals. or a bad piston ring which seems the most likely if its just coming outa one pipe. A compression test will tell ya if thats it
Mar 13, 2009 | 1979 Harley Davidson XLH 1000 Sportster
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
Excess amounts of Smoke coming out when in use
Locate where the smoke is coming from first. Run a dry test with just the stove. Many times excess smoke can be either oven cleaning chemicals burning off, or debris on the elements.
Jul 11, 2008 | Whirlpool AKZ159IX Oven
Kitchen Ranges Logo
296 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
