Question about GE (PSS26MSRSS) Side by Side Refrigerator
6 Year old GE side by side - freon line corroded and leaked
6 Year old GE side by side - freon lline corroded and leaked all freon. Is this a common issue? Technician (not GE Tech, a local repairman) stated that the corrosion was result of manufacturer placing an 8 inch section of foam insulation on the return line. He stated that the insulation causes condensation around the line and that condensation is trapped in the insulation. I didn't think copper could corrode, but he showed me the corrosion and pin holes in the line. He stated that he has seen this often in GE friges.
Has anyone had success getting GE to address this outside of the warranty (my warranty expired one year ago)?
  • 27 Answers
I am a tech that has worked on many ge ref's and have never seen GE do anthing outside of the units warranty. this is a common problem on ge units
Posted on Apr 23, 2010
    Director Badge:
    Uploaded 100 video answers.
  • GE Master
  • 488 Answers
Here is GE refrigerator that I repaired. Leak was at evaporator coil, but that evaporator coil comes with capillary tube and suction line already build into it. Hope that helps someone.
Posted on Feb 14, 2016
What happens when an air conditioner hose breaks?
You leak freon. I assume your lines on the passenger side along the frame corroded apart which is common. You need to take to a good chevy dealer and they should be able to do the repair on the lines.
Jul 06, 2014 | 2002 GMC Envoy XL
Frig/freezer Side-by-Side GE TXF27PF is not cooling. I purchased it used a year ago, and when we got it, it had to be repaired then as well. It had the same problem - not cooling, it was determined to be...
R 134A is for automobiles not refrigerators call a certified repairman. if it is leaking off they need to test for where the leak is and fix that first .
Mar 15, 2017 | GE Refrigerators
Water line leaks where line enters refrigerator
My 5 year old GE GSL25 refrigerator is leaking as well when using the water dispenser in the door. Removed kick panel to see better. The plastic water line on the door side of the union was improperly installed in a metal clip such that it was being crimped. This unintended pressure caused the water line to eventually fatigue and split. The door side of the water line needs to be replaced.
Oct 16, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I have a frost free upright ge freezer that quit working. No cold at all. It is less that 2 years old. Where did the quality go in GE? I have a GE microwave and it broke within the first year. Is it me or...
when the compressor is working and dont produce cold maybe the tube is leaking, causing the freon gas to scape. you need to reprocess your freezer to clean up and to find leaking tube to fix it. you nee a white line technician to fix your problem.
Jun 16, 2010 | GE 203 cu. ft. General Electric Upright...
Freezer will not freeze
replacing leaking evaporator on GE side by side. Watch this video to understand why its so expensive to fix freon leak issues.
Sep 25, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Leaking freon
Repairing sealed system GE side by side
Sep 23, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Trying to determine which is high side and which is low side
r-12 hasnt been used since 1994 and if you are sure, by looking on the model number tag, that yours does have r-12, then you need to find out where it is leaking out from. freon doesnt get weak, it will just leak from usually a corroded copper line.
the small line on your compressor is the "high" side and the larger line is the "low" side.
also r-12 is hard to find now but if you can get some then you might be able to buy some time until the freon leaks out again. i wouldnt plan on this unit working for much longer, but you might get by for awhile.
check the "heat exchanger" for signs of oil or corrosion. thats the most common place to find a leak. the heat exchanger looks like it has a small copper tube soldered right on to the larger tube, and is usually covered with a foam insulation sleeve.
Jan 07, 2009 | Refrigerators
Sub-Zero 511 Freon Leak
replacing leaking evaporator on Sub Zero R134A
Jun 22, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
731 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
