Question about Sony Playstation 3 (PS3) Console
It won't turn on everytime i try to it starts up and the the green light goes like a see through color then turns red
    Genius:
  • 1,044 Answers
It appears to be case of loose connection. Please check the power cable i.e. the plug and the connector at the other end. Check the power cable on any other device and see it s function ability. If it is working well on the other device then check your wall AC outlet and see that the cable joints inside are not loose. There is no other reason for light turning red except that there is no power supply. Heating can be ruled out as the system has not turned on.
Posted on Apr 23, 2010
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
My playstation 3 : everytime i turn it on it goes green then back to red and wont turn on? When it was working it just froze so i turned it off and since then it hasnt turned back on
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning .
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Everytime I start the stereo and turn the volume up even just a tiny bit I hear a few beeps the geen light flashes goes to a pinkish red color then back to green then shuts itself off. What do I do to fix...
If the amplifier isnt burned out, there is a good chance that one of the speakers is improperly wired, causing a short circuit. The amplifier is tripping the fuse to protect itself. These fuses **** themselves every time you shut off the unit. At very low volumes, the amplifier doesn't detect the short.
Apr 23, 2010 | Car Audio & Video
It turns on, but shuts down.
see bbc tv watchdog yellowlightof death
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
My camara won;t turn on everytime i get a orange light then it turns off completly
charge the battery until light changes from red to green, then when you put the battery back into the camera make sure you push the battery all the way down until it locks in place. Hope this helps
Aug 16, 2009 | Polaroid T831 Digital Camera
Monitor won't turn off
Monitor will be like that until it is powered off. Only when it is powered off, the light goes off and there will be nothing on display.
Jan 20, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
After a few minutes the color goes to intense red and green
My tv didn't turn green, but the red separated significantly. It started off happening after a few minutes of being on (I suppose the defective part was "warming up"), then it got to where it was like that immediately upon turning the tv on. In my case, I had to pay a tv repair man $350 for a new part. There are 2 microcircuits that control the color alignment--one that controls the red only, and the other controlls the other 2 colors, blue and green I believe. Maybe your part is the blue/green controller, mine was red. The repair man said these parts fail so rarely they don't stock the part. The cost of repair may be different for a different part, but either way you have to choose if it's worth that cost to you. If you get rid of it, I'll buy your tv stand ;-), I bought mine from a friend and didn't get the stand in the deal.
Dec 14, 2008 | Mitsubishi WT-42315 42" TV
Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Sep 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
