Question about HP 1240 Plain Paper Inkjet Fax
I cannot send a fax. A communication error 346 is printed
  • tere1 May 11, 2010
    Here is your solution
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
  • 24 Answers
SOURCE: Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Posted on Sep 25, 2007
FixinFax
  • 3085 Answers
SOURCE: fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Posted on Jun 06, 2009
xptareq2000
  • 1447 Answers
SOURCE: panasonic kx fp250 communication error. machine will not send fax
it is problem your telephone line or set up program
Posted on Jul 14, 2009
  • 6 Answers
SOURCE: When faxing error code 346 to one number so far
Here is the link to the solution to the error code as posted on the HP Solutions Web site:
<http://tinyurl.com/lu699e>
Posted on Jul 18, 2009
hamidquddus
  • 45 Answers
SOURCE: hp phototsmart c6100 faxing error 346
follow the trouble shooting from the below documents
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&lc=en&dlc=en&product=3645100#Error344
and this is the best resolution that we can give you ........................ thank you
HAMID
Posted on Oct 20, 2009
Error 346
There are a few causes for the errors you are getting...
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
And here's a few things to try...
*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable the ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved.
*Try sending at a lower transmission speed.
Dec 13, 2011 | HP 920 Plain Paper Fax
Everytime I fax i get a communication error 346 and have had phone line checked and hp techs are useless what else could cause this
The IBT Home Sensor does not detect the Belt Home signal.
If this fault is declared 3 times in succession, print mode will be disabled. In order to
clear this condition, reset NVM location IOT/Finisher 1221 to 0 in dC131.
Mar 26, 2011 | Office Equipment & Supplies
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Error 345 a communication error occured when ending a Fax .what is this and why does it happen?
I changed the fax resolution from "fine" to "standard" using the button on the keyboard.
After this, the page who was not faxable have been transmitted without problem.
Paolo
Mar 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP C7280 All in one wont send faxes
First clear the fax memory and then go to go fax menu and then settings
then DRPD set it 9600, and then try to send a fax ...
Good luck...
Feb 02, 2009 | Office Equipment & Supplies
Error message *346 with HP7310
since you have a 4 in 1 what i would do is go to your fax / printer settings and select spool to hard drive. There could be a possibility that all the data is not being stored on the fax machine. By sending your data to your hard drive first it will spool the data according to the performance and needs of your fax. Also check your time out feature on your fax machine. If the time out is set low it will send blank or only one sheet at a time. Because before the data is sent through the fax the system has already timed out. Another thing i found with the 4 in 1 is that as soon as you have your first paper going through you will want the second one right there ready to load. Sometimes if you wait to long before adding another sheet it will time out thinking you are done with your transmission.
Sep 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fax Error Codes
Sep 11, 2007 | HP Officejet 7210 All-In-One InkJet...
HP 1240 Plain Paper Inkjet Fax Logo
227 people viewed this question
Seeker5211
Seeker5211
