Question about Kyocera FS-2000D Laser Printer
Call service 6000:0035220 how can I fix without calling a service tech
I DISCONNECTED ALL THE WIRES FROM THE SWITCH ON A BLACK AND DECKER GW250 TO REPLACE IT NEED TO KNOW WHICH CONNECTIONS GO TO WHICH TERMINALS WITHOUT GOING POP BRIAN
theres usually a schematic on the back cover of apliances
this is why I hate being a service tech, not to berate you, but most times folks create more problems & then complain about the $$ required to fix their mistake, call a repair tech
Dec 23, 2014 | Dryers
Error code e2 on Rheem tankless water heater
e2 is not shown among common error codes:
Error e2 might be: Brownout condition or too low of voltage to thermostat. Double check wiring and check for 24 vac between R and C. E2 will clear 15 sec after proper voltage is restored.
Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat and typical generic manuals and common error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Model number and serial number are required for Rheem contact, and then they tell you what error code means without saying how to fix it, and then tell you to call service technician.
Tankless water heater manuals each say to have qualified technician perform yearly service. Most causes for common error codes are covered by yearly service.
Yearly service is fairly standard in the HVAC and water heater industry with advancement of high-tech 'energy' saving appliances. Of course all costs are energy, and the service call probably costs more that the 'energy' saved by energy-saving appliance. But with high tech stuff like tankless, it is good to have a reliable service guy who knows your machine.
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Jul 27, 2011 | Rheem Tankless Hot Water Heater...
I have a pink stripe at the top of my screen
Likely, the crystals in your light tunnel have shifted. Some repair shops can fix this without you having to buy an expensive light engine. This is not an easy do it yourself repair and I recommend calling a Service Tech.
Jun 06, 2011 | Sony Televison & Video
I forgot my password of nokia 3120 how can i open without loosing any data
Yes, you can open it without data loss. Simply call your cellular service provider's customer service number and request Tech support assistance. Tech support will verify that you're the owner of the phone then give you a master unlock code which you'll enter on your phone's keypad. This will unlock the phone where you can choose another PIN.
Feb 17, 2011 | Nokia Cell Phones
Code "CE20" red wrench appears
Hello.
This may not be the answer you want, but if you called for service and the tech did not fix the problem, the tech should return without a charge (if there was a fee).
For any service, for a computer, copier, auto or anything, if a service tech does not do his or her job and fix the problem. they need to return to complete the job.
Hope this helps.
Dec 31, 2010 | Toshiba Office Equipment & Supplies
Red light flashing 7 times on Phillips 42PF9431D/37 HDTV
No, I don't think you have a lemon, you have a great TV. It is just to complex for you to fix yourself. I think you have a ADC that went bad and needs to be checked out. You need to have a service adjustment done by your Service Tech. You just can't fix the ADC without clearing the buffers, and all the other procedures needed to fix this TV. I think your TV repair persons are probably just going over the complex procedures to fix your TV. This TV is real special, complex but, simple too. It has some 5 digit error code buffer procedures, I have never seen on any other sets. I do think you will need one sharp Philips Service Tech, and maybe Philips can help you with that if they haven't already. If you are not getting response from your Service Tech, I'd call Philips or a certified representative and have them get you one now. You shouldn't have to wait because, the local service techs haven't done their homework, or can't do the work.
Click here for a Philips service site, if needed.
Oct 25, 2009 | Philips 42PF9431D/37 TV
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
Canon ImageRunner 3300 G
The IR service manual says E602 means the harddrive is toast.A little tough to fix on an IR300 without the canon service tool on a laptop.It Fundamentally means you have to reimage the copiers hard drive with a new image.They don't call it imaging, they call it downloading a new OS, which must be downloaded from Canon.A trained IR service tech should be able to do it in about an hour.Good Luck
Apr 07, 2009 | Canon imageRUNNER 400S Copier
Maytag neptune
SM for the for the FAV6800A top loader
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Dec 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Ricoh 6513 streaking
Depending on your use IE lots of thick paper 150gsm plus.
The fuser rollers wear very quickly.
There is no Cheap fix for this.
These machines are very costley to run.
Ricoh Tech L3 22 years exp.
Mar 21, 2008 | Ricoh 6513 Copier
Kyocera FS-2000D Laser Printer Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
