Question about Brother MFC-9840CDW Laser Printer
Print error 6a
Wont' reset itself; cleaned, taken apart put back together; replace belt still hasn't fixed that error
Mix-it-up
  • 832 Answers
SOURCE: printer still wont work...
You've printed a lot, havent you?
It seems that you have to reset the flush counter, too. The flushing box is the 2nd reason for an error unable to clean. This is the small softbox on the left hand side where the printhead runs acorss for before it starts printing. You dont have to change the flushing box. Its OK to do a reset only:
Call up maintanance modus. press 8 then 0 then several times start mono until FLUSH XXXXXXXXXX (where X are No.) appears. Press the reset code again. After leaving the maintanance mode your mfc should work without a problem.
BTW: What exactly did you do with the waistinktank? I hope you have replaced it by a new one!
In case you have cleaned with water and reinstalled it,  the tank wont take up ink anymore! The ink will flow into the machine and the sensor will give you the error code again (That could be another reason why you still have the error code!)
Please be careful and buy a new one as a sparepart from a service partner who can be found on the brother homepage of your country!
Posted on Oct 12, 2007
Mix-it-up
  • 832 Answers
SOURCE: Error 46, 5B, and now 38
Did you deformate the pf encoder disc when reassembling the printer? This is the round foil being installed on one of the three wheels on the left side. This might be reason for the scratching sound.
5B happens when there is no ink within the purge unit tubes. It cant do a negative pressure to purge the printhead.
Try to fix the encoder disc and put some ink onto the purge station where normally the print head is in parking position. Afterwards the print engine should work again. Have ink carts placed well. The machine will try to purge the ink and is trying to do a neg. pressure again.
In case you wont be lucky you will have to go shopping to buy a new one...
Posted on Nov 08, 2007
Mix-it-up
  • 832 Answers
SOURCE: printer trouble
read my answer here:
http://www.fixya.com/support/t247395-brother_dcp_110c_error_51
Posted on Nov 30, 2007
Soulvisitor
  • 1113 Answers
SOURCE: brother 420
error 51 = The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Fix is
Switching arm assembly not engaged correctly If the switching arm does not move smoothly, clean it.
Ink cartridge/purge switch harness not connected correctly
Correct the connection.
Purge cam switch broken Replace the purge cam switch.
Gear(s) on the maintenance unit broken Replace the maintenance unit.
Paper feed motor broken Replace the paper feed motor.
Main PCB defective. Replace the main PCB.
Cleaning of these print heads rarely if ever is successfull, they are electronic devices unlike other brands of printers
Posted on Dec 04, 2007
  • 150 Answers
SOURCE: error code 6a on a brother dcp-7020 fuser unable
you need a new fuser. Not easy to install for most people I think I have a used one for sale for 40.00 805-520-3003 steven
Posted on Feb 14, 2010
I need to solve "Scan sensor error in samsung scx-3201g printer. printing is ok but no scanning.
Unplug the Printer then take the printer apart and use alcohol and a que tip to clean up all the connections and the sensor itself... let dry for say 30minutes or so and put it back together if it still dont work .. then buy a new scanner
Oct 11, 2013 | Intel Computers & Internet
Do i need to have my 2004 dodge intrepid anti theft code reset through a dealership if the heads and head gaskets were replaced? the entire top of the engine ws taken apart adn put abcl together.
i would disconnect the battery. removing both the positive and negative battery terminals. with both ends disconnected, hold the two terminals together for about 10 seconds. this will proform a hard reset on most chrysler vehicles. also, if this doesnt work, try turning the key to the on position, and then proforming the hard reset procedure.
Nov 04, 2012 | Dodge Cars & Trucks
My front crank seal is leaking can it harm my timing belt
Dear Calvin,
Just Have Your Front Crank Seal Replaced. The Water Pump Does not Need To Be Replaced At This Time. Try Taking It To Two More Mechanics. See what They Say. And Decide On A Fix.
Hope This Helps,
Alex :o)
Nov 18, 2011 | 2005 Dodge Stratus
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Do i fix the tray that wont open on my xbox 360
Either you have something sticky spilled on your unit, or you may have to replace the motor for the disc tray. Also take note if the tray is even attempting to open at all. If so, it might just need to be cleaned.
Oct 01, 2009 | Microsoft Xbox 360 Console
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Brother MFC-9840CDW Laser Printer Logo
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
