2006 Chevrolet Aveo Logo
Posted on Apr 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have chevy aveo 2006, enhine light up. did check, .. Troubleshooting PO133.. What that means?
happycouple7
Level 2:
New Friend:
  • Expert 189 Answers
  • Posted on Apr 23, 2010
happycouple7
Expert
Level 2:
New Friend:
Answers
189
Questions
0
Helped
56627
Points
403
Po133 means the 02 sensor is bad.
What is the 2007 chevy aveo engine number
PDF]2006 Chevrolet Aveo - GM Heritage Center
https://www.gmheritagecenter.com/.../gm.../Aveo/2006-Chevrolet-Aveo....
2006 Chevrolet Aveo: Refinements Enhance Value and Safety . ..... Engine NumberLocation . ... Manual Transmission Identification Number Plate (Y4M) .
2answers
Are there a lot of problems with chevy 2006 Aveo
Well, Gm couldn't sell any more geo metros so they renamed it the chevy metro. That didn't work too well so they renamed it the chevy aveo. Modern equivalent of the chevette. Research the Daewoo lanos, it is the same car under the skin.
chevy aveo
Oil light on 2006 Chevy Aveo but oil levels are fine
The oil warning light is for oil pressure, not the oil level in the engine.
Your owner's manual will explain it in detail.
You need to have the oil pressure checked with a mechanical gauge or replace the oil pressure sending unit to see if it is faulty.
3answers
2007 Chevy Aveo check engine light came on, code P2188, whats it mean?
P2188 System Too Rich at Idle (Bank 1) On a Chevy Aveo I have heard 2 different things that cause this code, 1. Check for any vacuum leaks in the intake , and 2. Check for oil bypass in the cylinders, Personally I don't know which is correct , But figured I could give you an area to check , Good Luck
What type of filter for a chevy aveo 2006
there are many filters in your car ..here is a list to choose from ..
http://www.car-stuff.com/mmparts/chevy-aveo/air_filter.html
1helpful
Does 2006 chevy Aveo has an engine cooling fan?
Yes, it has too or the car would overheat, check in the rear and front of the radiator.
2helpful
Why si the check engine light on on my 2006 Chevy
Tighten your fuel cap 3 times to make sure its tightned. don't push it in when you tighten it. Use Fuel injection cleaner like once a month... You may have gotten bad gas. Don't use 100 percet gas. Use gas with ethenol... you get better gas mileage. I go through 3-4 tanks a week. I use the 87 octane and I put Berrymans Fuel injection cleaner in once a week. I don't know about your hesitations though I drive a 5 speed
10helpful
5answers
Chevy aveo error codes. I have a check engine light on.code p2135
P2135 Throttle Position Sensor (TPS) Property Malfunction, remember this is not a car that is built by GM it is a Korean import.
I just took my chevy aveo 2006 to get the oil change but the light is still on , what can i do?
the owners manual should have info on how to reset the light. check under maitinence.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
