Question about Necchi 4595 Mechanical Sewing Machine
There are loops of thread under the bobbing when i sew
    Genius:
  • 1,116 Answers
Lift the presser foot and pull about 8" of thread through the needle.
When threading a sewing machine, make sure the presser foot is up as this opens the tension control so the thread can be properly seated and controlled once the presser foot is down.
Posted on Apr 23, 2010
sew dutch
  • 25 Answers
SOURCE: Thread looping on the bottom
Thread looping on the bottom means you have a problem with the top thread. In your case there is no tension on your top thread. Take all the thread out of the top and start threading over. Make sure you follow the correct path and make sure the thread goes through the tension discs. Then at the time of sewing, make sure your foot is down (this closes the tension discs and gives the thread the tension.) You may have worked on the tension setting while not realizing the thread was not in between theses discs, so also make sure the top tension disc setting is in the average before sewing.
Good luck.
(If you see loops on top, it means you have a problem with the bottom thread)
Posted on May 25, 2009
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
  • 17 Answers
SOURCE: Singer 2010 does not make the loop under the plate, to sew.
set up needle properly...
Posted on Dec 25, 2009
  • 255 Answers
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Posted on Jan 26, 2010
  • 1116 Answers
SOURCE: bobbin thread does not loop up when threading
There are so many thing you need to re-check.
First clean out the bobbin area to be sure there aren't any thread tangles still there.
Open the manual and start from the beginning with threading the machine with the presser foot lever UP - always.
Read the instructions and do not rely solely on the pictures as we all sometimes rush to do (I am just as guilty as the next person to do this).
Make sure the bobbin thread is feeding from the bobbin case in the correct direction.
Hold onto the end of the top thread (after needle has been threaded) and lower then raise the needle to catch and bring up the bobbin thread.
Place the fabric under the presser foot and as you hold onto the ends of the top and bobbin thread, hand walk the first stitch, then use the power pedal.
If you need a manual, you can download (free) from Singer - http://www.singerco.com/accessories/manuals.html
Posted on Mar 25, 2010
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
Bobbing thread pulls right out when I don't seam
Either the upper thread is not seated properly in the tension disk or the upper tension is too loose.
When threading the upper thread, be sure to always raise the presser foot so the tension disk is released and the thread can seat all the way.
Test the machine again, and if the upper thread is still looping under the fabric, tighten the upper tension.
May 17, 2016 | Sewing Machines
Upper thread loops
Hi Nisha, The link below is a YouTube video showing how to thread your sewing machine, Also there's videos down the right side of the link that may help as well.......... CHEERS..
Sewing Machine Tension Tips
May 07, 2016 | Sewing Machines
Machine isn't sewing right. Underside thread is very loopy. Was sewing fine but thread jammed in bobbin area.
Remove all remnants of the thread from the bobbin area.
First thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the lot by thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. Also try new needle.
Oct 27, 2015 | Sewing Machines
Janome 4400 bought new bobbin holder but still have lots of issues with thread looping while sewing. The repair person says I pull the thread forward after cutting it and undo the proper bobbin threading....
looping the material ( bird nesting) is an indication of incorrect needle thread tension before threading the needle pull the thread and there should be resistance to the pulling
Nov 15, 2017 | Janome MC 4400 Computerized Sewing Machine
My bobbing thread is looping on all types of stitching. Machine was working fine. Cleaned all reachable components as per manual.
Most of the time it is in your top threading or a bad needle. Try this and if it doesn't work call Singer at 1-800-4singer. I am hoping that it is not the timing. Good luck
Oct 05, 2010 | Singer 7442 Mechanical Sewing Machine
How do i thread this machine
thread this machine by taking a strain of thread from the spool pull it to the thread guide on top left side of machine criss cross the thread when you wrap it around the thread guide pull thread down and loop it under the needle thread tension control dial bring thread up and loop it on the thread take up lever, continue down to the needle looping it first around the metal piece above it then through the needle it self pull thread to back of sewing manchine with the bobbin thread
Feb 12, 2009 | Brother LS-1217 Mechanical Sewing Machine
Bobbin Case Popping Out
I had the same problem with my singer 20u professional. I tried to find the answer here but no help but I made a call & she said the bobbing might be too big fer the bobbing holder. the bobbing holder is the round metle thing that fits in ure machine. u have to make sure the bobbing ( the thang that holds the thread is the exact same size as the bobbing holder. Hope this helps.
Dec 05, 2008 | Singer 7422
Breaking needles bobbing in huge ball and thread not even
i cleaned and oiled it and it fixed itself.
Nov 15, 2008 | Sewing Machines
Necchi 4595 Mechanical Sewing Machine Logo
140 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
