Question about Soyo Dymond DYLM017A 17" LCD Monitor
Cannot see the full screen
About 1/4 of the screen is blankon the left side. Can't do anything with the mouse to cursor over. Can this be corrected? Thank You.
  • 11,361 Answers
Try go to menu and look for 'Factory setting" or 'Reset'. You can also have problem some where in the power supply, you may have to open it up and look for bad caps. Please look through my albums here: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
so you will know what to look for inside. The inverter and the back light lamps are more likely to be OK because the screen did not black out, if the inverter or the lamp assemblies are bad, you will not see anything on the screen.
Posted on Apr 30, 2010
    President:
  • 1,768 Answers
No, your monitor is needing service
The inverter that corrects the picture and the luminous tube ( florescent) that gives light to the LCD is failing. These and some board components are malfunctioning.
Posted on Apr 23, 2010
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
How to change orientation of monitor
I'm a little unclear of what you are asking.
1) Screen has turned on monitor?
Press the CTRL key, and ALT key down at the same time.
Now tap on the Left Side Arrow key, until the screen is oriented correctly again.
2) Screen on monitor has shifted left, right, top, or bottom?
Use the controls on the monitor to set it correctly again.
3) Using dual monitors?
Right-click on an empty space on your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on Settings.
The monitor 1 icon is supposed to be your Primary monitor.
The monitor 2 icon is the Secondary monitor.
Ordinarily the Primary monitor is on the LEFT side, and the Secondary monitor is on the RIGHT side.
Just as shown in the Settings window.
If you wish to move a monitor to the other side, go to the monitor icon you wish to move.
Put your mouse cursor on the monitor icon you wish to move.
Left-click, and hold the left mouse button down.
Now drag the monitor icon you wish to move, to the other side.
Not doing it for you?
Then post in a Comment with more exacting information, as what it is that you wish to do.
Regards,
joecoolvette
Aug 02, 2012 | E-Machines eMachines Desktop PC
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Help.. my acer aspire computer screen has turned vertical on my notebook and the cursor isn't working.. what do I do?
Well, to get the screen back to normal, press Ctrl + Alt + Up Arrow. As for the cursor, try rebooting the computer after changing the screen back to normal. If that doesn't work, try another external mouse to get to the mouse settings from the control panel and see if anything has changed.
I hope this helps! Thank you for using FixYa!
Jul 14, 2011 | Computers & Internet
How can i capture screen with visible mouse cursor in windows-7 ? is it need any software ?
Hi.
You can capture a screen shot with the mouse cursor there by pressing the Prt Scr key. It should be on the top right hand side of the keyboard. Create the screen you want to capture and then hit that key, then open Paint which you will find in Start menu>All Programs>Accessories and then paint. Once you have opened paint up click on paste on the top left hand side and you will see your screen shot appear in the paint window. To save the picture click on the little floppy disk icon at the very top left of the paint window.
If there is anything else please post back.
Regards.
Apr 27, 2011 | Computers & Internet
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
Cursor and pages opening up off the right side of my desktop
This is a monitor setting. use the menu button on your monitor to shrink the screen size from side to side. The menu button usually toggles you through the settings and the + or - buttons adjust the settings.
This happens a lot if your on a small desk and bump your keyboard against a low sitting monitor.
Regards
Mar 24, 2009 | Computers & Internet
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
The cursor is frozen in the middle of the screen.
check your keybord and mouse pin.
also press F8 key then run in safe mode
then go to run
type chkdsk /r
then press y
then restart your pc
your pc run disk checking
then it auto restart .
Sep 29, 2008 | Gateway (4000274) Motherboard
Soyo Dymond DYLM017A 17" LCD Monitor Logo
102 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
