Question about Homelite ZR10926 16 Chain Saw
Icarburator adjustment THINK THE NEEDLE VALVES ON MY HOME LIGHT CHAIN SAW NEED READJUS
    Brigadier General:
  • 4,088 Answers
Before adjusting the jet screws to fix something caused by other factors, look for a clogged fuel filter, air cleaner, or muffler. Check the condition of the fuel lines and the fasteners on the carburetor. Make sure the primer button is soft and not cracked. These saws use a Walbro brand carburetor and an excellent article on troubles and repair can be found at: http://www.drystacked.com The pictures are out of focus and he neglects the pumper chamber action, but the theory is very helpful--especially the position of the lower chamber gasket/diaphragm. Hope this helps!
Posted on Apr 29, 2010
Testimonial: "THANK YOU I WILL TRY AS SOON AS I CAN . MY SAW IS IN THE MOUNTAIUNS AT ANOTHER LOCATION, THANKS AGAIN. VIC HALL"
How do i set air on husky 435 saw to fix boggy runnin
Mitch:
Adjust the fuel and air mixture screws while the saw is running... you'll find that "sweet spot"... it just takes a little patience! Small adjustments... If you over adjust and the saw quits running or starting, GENTLY turn both screws in all the way (don't damage the needle valves or seats) and turn both out one and a quarter (1 1/4) turns out. The saw should start, then adjust from there.
Jan 01, 2013 | Husqvarna GAS CHAIN SAW 435 16"
Set the carb for a mcculloch 3516 chain saw
Carburetor Adjustment
There are no hard and fast settings.
A good initial starting point for the "H" and "L" needle valves are 1.5 turns CCW from lightly seated.
The "T" adjustment enters here (idle speed) and there is no initial setting without a tachometer, depending on age of your saw there may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Start with a fresh mix of fuel. Put ALL of the old mix in any 4 cycle engine and start new. I suggest 50:1 regardless of what your manual says.
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; once marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
Now we adjust for performance. The best performance adjustment procedure I have found follows.
Madsens Shop & Supply, Inc. Carburetor adjustment (All saws homeowner and professional are the same)
http://www.madsens1.com/saw%20carb%20tune.htm Read step 4 (allow it warm before making adjustments).
There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment is often indicative of a larger problem.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 08, 2010 | McCulloch Garden
Can you please tell me what the carb adjustments are for the Poulan 18in. wild thing chain saw?
"L", "H", and "T" adjustments are all explained on the link. It is a very good carburetor setting procedure.
Start with “L” & “H” needle valves 1.5 CCW from lightly seated, then adjust for performance as follows.
Carburetor Adjustment by Madsens.com
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment may be indicative of a larger problem.
Lou
May 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
GETTING MY HOMELITE 150 STARTED.
Hello Vic;
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I searched for an OM with no good luck. Please contact them here:
Homelite.com (Contact Us)
https://register.homelite.com/contact_us/new
Ask they create an on line location where OMs can be found and down loaded please.
Lou
Apr 29, 2010 | Homelite ZR10926 16 Chain Saw
Will not stay running
Lou
Apr 27, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
142 chain saw. Starts but will not pick up when
Remove, clean and reinstall the muffler and spark arrestor, if no better the "L" needle may need adjustment.
Most chainsaws die because they are are run lean. I am going to inject a little Lou theory here. Air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to adjust high and low settings on carb for a homelite chains
Me know how! Want know who?
I would start with both the "H" and "L" needle valves at 1.5 turns CCW from lightly seated then adjust for performance as follows:
Lou
Mar 17, 2010 | Homelite ZR10926 16" Chain Saw
What are the carb. settings for modfle 1950
Start with the "H" and "L" needle valves 1.5 turns CCW from lightly seated. then tune for performance like this:
Clean the air filter and spark arrestor; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run. If the saw cannot exhale it cannot inhale.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Lou
Mar 08, 2010 | Poulan Pro Chain Saw 46cc 20"
How do you set up a carb on makita chain saw
You provide no manual, I chose a "DCS34" a link follows: http://www.makita.ca/data/upload/tools/DCS34%20F-E.pdf
It lists no starting point for the "H" and "L" needle valves, I recommend 1.5 CCW from lightly seated. then tune for performance like this:
Lou
Mar 02, 2010 | Makita 33cc 14-Inch Bar 1.9 HP Gas Powered...
Adjusting carb on husqvarna chain saw
Hi First turn them(H and L) clock wise until the end and then adjust.
high speed H=3/4 turn
lowspeed L=1 1/4 turn
idle speed T adjust accordingly
best regards savumihai71
Jan 19, 2009 | Husqvarna Chain Saw 20" Bar
Homelite ZR10926 16 Chain Saw Logo
130 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
