Question about LG WD-1045FH Front Load Washer
LE flashes up - LG WD-1045FH Front Load Washer
  • LG Master
  • 3,051 Answers
HELLO THERE:
Ok FIRST i believe this to be a Hall sensor that is either acting up or is failing you all together so.
here is what you can do about it to find out for sure.
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error: try it 1 more time
Now if you still get the error
The Hall sensor (part number 6501KW2001A) has failed. and will deffinatly need to be replaced
If you feel comfortable about ordering the part on lin e you can get the part from appliance parts pros.com ok or contact your local repar service center
I would also check to see if the machine is still under warranty ok
Hoe this isvery helpful for you
Posted on Apr 23, 2010
Testimonial: "very helpful thnks"
2004 toyota le check light is flashing what does that mean?
-Use scan tool to read the code and find out what cause that and
fix it.
Good Luck
Mai
Mar 30, 2015 | 2004 Toyota Sienna LE
Can I install a flash player on my le pan II?
Why you want to install a flash player? I believe Android Tablets don't need it
Aug 25, 2013 | LePan Le Pan II Android Tablet with 1GB...
Bonjour a vous j'ai un proble avec mon appareil phpto CASIo NUMERIQUE EXILIM OPTICAL 3X je ne parvient pas a activer le flach
Voici le lien pour t?l?charger le manuel de votre appareil photo,http://www.onlinefreeebooks.net/download/11943/casio-exilim-ex-fh25-digital-camera-user-guide.pdf. Il suffit de suivre les instructions ? la page 46 et 55 ans si vous voulez un obturateur en continu au flash
Mar 27, 2011 | Cameras
I want to "lock" the flash drive with a password.
    Encrypt Individual Files and Folders on a Flash Drive
  1. Step 1 Choose "Tools" from the menu bar at the top of the program, such as Microsoft Wordmag-glass_10x10.gif, and pick "Options."
  2. Step 2 Select "Security" from the many tabs displayed in the new popup window. Create a password in the "Password to Open" or "Password to Modify" section and click "OK" at the bottom of the box.
  3. Step 3 Confirm your password when prompted. Drag the password protected files to your flash drive. To open a protected file, enter password when prompted. Remember, passwords are case sensitive.
  4. Encrypt Entire Flash Drive
  5. Step 1 Download and install the freeware program "Cryptainer LE" onto your PC or laptop. Enter a meaningful password from 8 to 100 characters and define the file location and size, which you can change at a later time. Enter your password when prompted.
  6. Step 2 Install Cryptainer Mobile when the Cryptainer LE installation is complete. Select "Tools" on the menu bar at the top of your screen. Select "Install Cryptainer Mobile" and follow the prompts. The Mobile version comes with the LE download.
  7. Step 3 Close the LE version on your desktop. Select a location and meaningful password for the Mobile version. To protect important files and folders, drag and drop them into the vault, the location of the encrypted files.
Jun 24, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Stops and flash le code
Le is a locked motor error.  Sometimes glass, or food gets stuck in the bottom of the sump jamming the motor.  Take it apart from the top to check for clogs.  When you get to the impeller the screw might be reverse thread.  If there is nothing stopping the motor, you will need to replace the motor.
Dec 19, 2009 | Washing Machines
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
Charging problem
solution magique
vous avez besoin d'une pile carré de 9v 2 file électrique
branché le (-) de la pile avec le (-) est le (+) avec le (+) de la battrie environ 20 seconde est réessayer.
Aug 22, 2008 | Casio Exilim EXZ75 Digital Camera
LG WD-1045FH Front Load Washer Logo
82 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
