Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Runs very slowly, and when moving the dial to run it cuts off.
  • 40 Answers
This happend to me to I jest needed to get a new blower
Posted on Apr 23, 2010
Mover sometimes does not move and other time moves real slowly
ck belts that run hydraulic pumps for tire drive , it might have slipped a bit with chain caught , now belts skid instead of transferring power to pumps , also these pumps might have a manual pressure relief reset , I was thinking they only used them on bigger units , but you might have one as well ,hey its possible , this will need to be reset prior to continuing mowing (refer to manual for location )
Jun 23, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
My Bosch jigsaw suddenly seems to run too slowly. It just doesn't cut as agressively as when new, and seems to turn less rpm. what's going on with it?
This may seem dumb but did you accidentely turn the variable speed dial on the trigger down? Not sure which model you have but that is the most common problem that comes into my shop with certain models.
Dec 17, 2012 | Bosch Saws
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
My timer manual switch works,it turns the outside lights on and off. However the automatic dial,even when plled out and set to time to operate does not work.What 's going on? Isit me?
The two tabs are for On ad OFF.
One is slightly longer than the other. If the OFF tab is in the ON location, it won't work, it'll just click past the time and not flip the paddle to ON.
Try this, turn the dial (NOT pulled out) around slowly and see if it flips the paddle to ON. Keep turning it, slowly, and see if it flips to OFF.
If it works while you're "helping it" then it should work automatically. If it doesn't, maybe the gear is damaged and it can't move past a certain point.
Does the time move? Do you hear the motor running? I've seen the motors go bad. The manual flipping will work then, but the motor isn't running the clock around.
Jan 30, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
R55 model. runs for a while & cuts off. [1]
Dials? I assume you are speaking of the air pump adjustment screws.
How to set the pump pressure
Nov 20, 2010 | Reddy R60A Utility Heater
Can you tell me the order in which each componet of a gas furnace comes on to start the furance?
Yes there is a sequence:
0:00 Dial for fan/limit switch is at 70 deg position. Furnace is cold. I turn T-stat to 80 deg to start furnace.
1:00 Burner comes on and dial begins to move slowly up.
2:30 Dial at 140 deg and fan motor comes on. Dial never goes above 150 deg.
3:00 Burner turns off. Dial slowly moves back towards 90 deg.
4:45 Burner turns on and dial is at 110 deg.
4:50 Fan turns off with dial still at 110 deg.
5:30 Burner off. Dial at 120 deg.
6:15 Fan on. Dial at 140 deg. Burner is still off.
7:00 Burner on. Dial at 120 deg.
7:40 Burner off. Dial still at 120 deg.
8:30 Fan off with dial at 110 deg., and it quickly snaps back to the 80 deg. position.
8:30 plus, cycle continues.....
Mar 25, 2010 | Heating & Cooling
I just bought a torch. and i was just wondering how to use it. i was just wondering how much oxigen to gas i use
depends of the torch you are using, if you have a single ought or 0 then run the oxygen at about 17 pounds and the gas at 7 pounds, this should give you a good clean cut. Remember to turn on the gas all the way, since gauges run slightly off you may have to increase one or the other, on the handle and barrel assembly you can adjust the gas first light the gas then turn on the oxygen get a good blue flame all even on the tips then turn the oxygen knob all they way on then when cutting be sure to heat the metal forward and move forward at a 17 degree angle, when you hit the cutting lever after the metal turns molten hit the oxygen lever move evenly and slowly if you need help with welding with it let me know and I CAN GIVE YOU SOME TIPS ON GAS WELDING.
Nov 21, 2009 | Northern Tool Dual Turbo Propane Torch Kit
Engine will start and run in choke position. Move
Either carb floats are sticky, or the needle and seat are warped and worn and need to be replaced. I first would pull the carb off and apart and soak in solvent for an hour or 2 and then blow dry and reassemble.
Nov 10, 2009 | Audio Players & Recorders
No Dial Tone
Dear Sanyte1226,
Double Check that all handsets are registered, and make sure that you don't have to many phones connected to the jacks throughout your home. If all fail, very slowly, make sure the phone is on speaker, and slowly move the telephone port into the jack SLOWLY like slower than slow motion. If you here clicking, keep pushing it in slowly until you here a dial tone. I know this has happened to me before.
Best of luck, The Writer.
Jun 02, 2009 | Uniden DXAI5188-2 Cordless Phone
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
125 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
