Question about HP OfficeJet J4580 All-In-One Laser Printer
My printer is not copying. It will print from my computer.
Why is my hp officejet only printing 1/4 page from copier? It prints fine from the computer.
Not enough information.
What printer model?
While scanning and copying?
Try resetting your printer to manufacturer defaults and try again.
Aug 06, 2014 | HP OfficeJet Office Equipment & Supplies
What button to press to copy a document ?
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
Hope this helps? Good luck!
Jul 07, 2011 | Office Equipment & Supplies
My printer says copy but not print how can i solve this when i copy nothin is on the sheet it prints how can i print my document
Place any document on the scanner glass of the printer and press copy.The printer will copy your document.If we want to print any document from computer,the Kodak home center should be installed on your computer.If you have not has the software,download it from www.kodak.com/go/aiodownloads. Your issue will be solved.
Dec 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Need to print more than one copy
If your printing from Windows, when the print dialogue box comes up look for the option number of copies. Change that to the specified number you want to print out and then hit print.
Jun 13, 2009 | Canon PIXMA IP3500 Photo Inkjet Printer
My printer will not print from the computer
its a printer driver issue for me..
I think you need to reinstall your printer driver again..
first you need to uninstall existing printer driver ..and restart your computer ...and then reinstall you printer driver..
why you need to reinstall?
because the printing application for the printer has been corrupt or missing..only the copy and scan application is running properly..
that's why it only scan and copy..but not print some document..
thanks for using FIXYA...
Have a good DAy..ahead^_^
May 24, 2009 | Epson Office Equipment & Supplies
Copying/printing--keeps cleaning rather than printing
hi,try disconnecting printer.restarting computer.then reinstall printer.
Mar 04, 2009 | Brother MFC 3420C All-In-One InkJet...
Switching from copy to print from computer
If you look carefully at the printer you'll note that there is no button for "Print" and the reason for this is that all the other functions are for using the printer as if it wasn't connected, nor needed a computer.
All your printing functions that DO use a computer require you to interact with the printer via the computer.
In short, to use the printer from the computer you'll need to make sure you've installed the correct drivers (see your installation CD or the Canon website) and then plug the printer in using a USB cable connection to your computer. If the computer recognises the printer you'll then be able to print.
In a nutshell if your printer is connected and drivers installed properly it doesn't matter what your printer has selected on the printers own control panel, you just print :)
Hope that helps.
Feb 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
HP OfficeJet J4580 All-In-One Laser Printer Logo
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
