Question about Swiss Audio SWL1281 Car Subwoofer
I need to know how to wire 2 swiss audio 12 inch spl 1291 subs to
A boss 1000.5 mono block amp
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
Can my la590 American legacy 2 series 800 watt handle Boss CX122 Chaos Exxtreme 12-Inch Subwoofer 4-Ohm Voice Coils??
It is only stable to 4 ohm mono(which is 400 watts RMS or a bit less not the max rating of 800 watts which is a PMPO rating).
Your Sub would have to be wired in series(8 ohm final load, if you wire it in parallel 2 ohm-you will fry that amp).
Jan 07, 2014 | Car Audio & Video
How do I properly wire 2 12 inch 40 cwr122 subs to a Kicker 12cx1200.1 mono amp
Need to know the resistance of the speakers you are wiring, are they 4 ohm or 8 ohm speakers? Is this for car or home audio? What resistance does the amp show it is capable of handling?
Oct 13, 2013 | Kicker CVR12 Car Subwoofer
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
Wiring
moz-screenshot.pngthis is the best way if it is a dual 4 ohm ....
this is the best way if it is a daul 2 ohm sub...
Jan 28, 2010 | Boss REV-650 Car Audio Amplifier
I have a boss class-d mono bloch 3000d When i turn the volume nub on the amp up it make noise throught the speaker
This is just a thought, what gauge wire are you running to your amp? The more current that passes through a wire the higher it's resistance becomes therefore dropping voltage across the wire and ultimatley not allowing your amp to perform as it should.
Jan 04, 2010 | Boss Car Audio & Video
Amps that work with 10" RFZ2410
well how manny amps can the sub hold? any amp will work you can bridge it to doulbe the power but i would say a 200 wat amp would do you good
Aug 02, 2009 | Rockford Fosgate RFZ2410 Car Subwoofer
Swiss Audio SWL1281 Car Subwoofer Logo
60 people viewed this question
Top Swiss Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Swiss Audio Car Audio and Video Expert? Answer questions, earn points and help others
