Question about Sony KV-27FS13 27" TV
Color switches to b/w, then a click, then color, then b/w, click, etc.
The TV has worked just fine since January 2002 until today (March 22, 2008). The picture shows just fine in color, then 1 to 2 seconds later it blurs somewhat and the color goes away and there are a number of horizontal lines, then at the 4 to 5 second mark, it makes a click noise, then goes back to color, then b/w, then click noise. I bang it on the side, top, etc. and nothing. I took it away and put another TV in its place and that works just fine, so I know it is not the cable. Any ideas?
  • 129 Answers
Good day.
I think your problem is with the crt circuit. It is the one on the rear of your picture tube. Some loose connections may occured in there. Also, check if the flyback is arching. Sometimes, the voltage on the flybach itself causes this.
chris
Posted on Mar 23, 2008
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
YELLOW SCREEN
How old is the lamp? the lamp may be failing and or the optical block may be damaged.
Jul 13, 2008 | Mitsubishi VS-45609 TV
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Codes are 0065, or 0405,or 0037
Code are 0065, or 0405, or 0037
Code are 1293, or 1206, or 0206
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
We have a Panasonic DMR-EH55 dvd recorder, it worked just fine until March, 2009 when Shaw quit subscribing to tv guide. Has there been any resolution to this issue?
Shaw like Time Warner in many areas of the U.S. will never go back to TV guide.
Your best bet is to switch to the competition in your area.
Jan 31, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
My Canoscan 4400 stopped working.
If you have extra Power Adapter for your Scanner which the same DC Current then use it. And if not bring it to your nearest Computer Center to be check.
Oct 01, 2009 | Canon CanoScan 4400f MultiFunction Color...
Turned AC thermostat to Cool today - AC didn't come on. The last time we used AC (March 2009) it worked fine. I can hear the AC Relay Board, inside the trailer, click when switching from Cool/Off &...
Just clicking is all your getting from ceiling assembly? No other modes work such as fan, or furnace? If that's the case, check your circuit breakers to make sure it didn't trip.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
LiquidVideo monitor will not come on at bootup.
Blown capacitors internal to the monitor they can be replaced by soldering.
let me know what you want to do
Mar 22, 2009 | Computers & Internet
Picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Apr 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
PC computer will not detect Free Agent external hard drive. It has been operating just fine until today, March 20.08. Icon on desktop has a questions mark on top of icon.
Hello, right click on icon and click open. Or double left click on icon and see what it tells you. I sounds like cable or power has been disconnected. Could be driver needs reinstalling. Could be a number of things. Click on icon and see what it tells you. Hope this helps..
Mar 20, 2008 | Computers & Internet
Sony KV-27FS13 27" TV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
