Question about HP DeskJet F4280 All In One Printer InkJet
My printer HP deskjet showing cover open while i switch on my printer
SOURCE: printer deskjet 3650
saks
Posted on Jul 10, 2008
  • 33 Answers
SOURCE: hp deskjet d1430 not printing
If you double click on the print que, look at the status heading...what does it say? If it says printing and then windows gives you a "this document failed to print", then you probably have a driver issue. Delete the printer and re-install. If it says paused then right click on the job and clickon resume. You might also want to check in the printers and faxes folder, right click on the driver for the printer, see if an option is there that says resume printing, click it if it does. Also right click on driver and select properties, under the ports tab see if the correct port is selected. Best I can do without knowing more detail.
Larry
Posted on Dec 01, 2008
nassimjd
  • 104 Answers
SOURCE: HP Deskjet 3915 Printer ''Door Open''
open all the doors (fron and back) make sure there is no paper jam .
close all doors, one at a time.
turn off, wait for a few seconds,,,
turn on
and your problems is solved.
Posted on Mar 26, 2009
  • 192 Answers
SOURCE: hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Did you puch down on the cover some models requires you to puch down so that sencer knows it is completly in place.
Posted on May 20, 2009
cene765
  • 787 Answers
SOURCE: Hp Deskjet 3940 light keeps on blinking fast, and
This is a problem in logic board assembly.The cost of repairing is profitable, then better think about new printer.
Posted on Nov 24, 2009
Hp deskjet 3920 door open error
Open the door, left side above on off switch there is contact for door sensing switch, press that check carriage assm moving right side?.. *if yes insert small peace of paper in it, use it..But if you want to replace the cartridges remove the paper object.** if carriage assm not moving open the upper cover check the switch..
Sep 20, 2011 | HP DeskJet 3940 InkJet Photo Printer
My 3745 deskjet will not print the printer weill not work the switch light is flashing all the time
Just unplug the power cord and remove the cartridge and clean it and also It require servicing open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Have a nice day and do not forget to rate please...!
Dec 24, 2010 | HP DeskJet 3745 Printer
Keep geting the door open error message for HP Deskjet 3920/3940. What door and how do I close it?
The front cover is the door. Make sure no obstacle resides between cover and chasis.
There is a small switch (under cover) on the left side of the printer.
If for any reason you get same error then insert a small paper between the switch and chasis.
good luck
pls. vote for better service
Nov 11, 2010 | HP DeskJet 3940 InkJet Photo Printer
On my laptop, my printer is not printing documents. It shows that the "Door Open" message..the door is clearly not open. Please help
There is plastic piece on the cover that push a switch inon the right side when the cover is close. make sure it is not broken. You can also use your finger or a pencil to push in the switch while the cover is open to test that the swich is working.
Nov 06, 2010 | HP DeskJet 3740 InkJet Printer
All light are on on the my portable printer HP deskjet 460
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 09, 2010 | HP Deskjet 460c InkJet Printer
When i plug my hp deskjet 3650 the power light keeps on flashing and no activity inside the printer. pls. help!!
Nov 16, 2009 | HP DeskJet 3650 InkJet Printer
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid.
Geezer Geek
May 20, 2009 | HP DeskJet 6840 InkJet Printer
The ink light blinks all the time since I replaced the color
The ink light flashes when the top cover is open...check the switch that tells the printer when the cover is closed.
Feb 23, 2009 | HP DeskJet 842c InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
91 people viewed this question
Seeker5211
Seeker5211
