Question about LG Computers & Internet
This is about an RH199H. I changed from 4:3 to 16:9. My TV is 4:3, and I changed just for an experiment. After that, no signal from DVD to TV. (I´ve checked the scart cable.) When I push Setup, "Setup" appears at the DVD display, but I cant see the menu because the TV is black. Sincerely yours /Lars
  • 344 Answers
If the scart connections are secure as you have stated (checked both ends, cable should be in scart socket AV1 on rear of DVD).
Other possible causes,
TV/DVD mode for the recorder is set to TV, press TV/DVD on remote repeatedly and choose DVD mode. (TV indicator disappears in the display window).
TV is not set to correct source, should be an AV button on TV remote to toggle between TV and other input sources.
If the unit is not operating as it should then you can reset it it by pressing and holding the POWER button for at least five seconds, this will force the unit to power off and then on again.
Unplug the power cord, wait at least five seconds and then plug it back in again
Hope this helps
Posted on Apr 23, 2010
Toshiba Dvd won't work properly with my new TV
if your old tv was an analog one you need a digital converter box to change to the new signal.. new tvs wont recognize the analog signal..temporarily you may be able to use your laptops' dics player as a player for your discs..
Jan 11, 2014 | Televison & Video
Don't know what channel the dvd is suppose to be on. TV is set on 4 and I can't get dvd to change to four.
DVD players don't carry signals to channels. They carry signals to inputs. Check the back of your TV. If your cable coming from the DVD player goes into "video 1" set the tv to video 1, etc.
Sep 07, 2009 | RCA Televison & Video
No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
May 07, 2009 | Yamaha HTR-6130 Receiver
Changed from satellite to cable, not cannot get channels
You have an input button on your remote. push that button and look on the screen to see where your tv signal is coming from. Change it to the appropriate one for the cable. Experiment by going from choice to choice.
Apr 07, 2009 | Protron PD-DVR100 DVD Recorder
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Problem hooking dvd-1080p8 to 22inch 720p RCA TV LCD HD .
I changed the output on the Dvd player to720p and that seemed to cure the signal problem,that is what the TV is,so that makes sense,I had already assumed that would do the trick.However,as I said yesterday,the manual states it only upgrades the signal in 1080p,I went by the deacription on the box which said it was compatible with all 3 signals.So after all of that I am not sure if it is going to upgrade the signal to 720p,if you have the answer I would appreciate knowing,I can certainly live with this .but it would be nice to know.
Dec 27, 2008 | Samsung DVD-1080P8/XEU DVD Player
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Unable to view setup menu on TV screen
I had this same experience and after hours of attepts to fix it (including the suggestions on this site) I found that the company that installed and set up my system literally disabled the "set up" on the remote so that it could not be changed. To fix this (and/or confirm that this may be your problem) reference page 39, "all reset functions" to reset your remote back to factory settings. As soon as I did this and hit "set-up" -- the set up menu popped up and worked appropriately. Hope this works for you!
Dec 16, 2007 | Denon AVR-3802 Receiver
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
