Question about Philips 20PF5120/01 20 in. EDTV-Ready LCD Television
Loud schreikin noise and cuts off.
Tv makes loud noise and cuts off and on a few times and after about 5 times of loud schreiking and off and on then the tv will work fine until you turn it off again.
    President:
  • 1,768 Answers
It sounds as thought the main-board of the TV is arching or shorting out. This is due to a faulty component in the power section of the TV . It is about to completely go out.
The main board need to be checked for bad components.
Posted on Apr 23, 2010
My olevia 237-t11 turns off by its self and sometimes makes a loud screcheen noise
Sounds like either the main or display power supply is failing. Might consider a new TV. Parts could be found but it might be hard to find them.
Aug 28, 2014 | Olevia 237T 37 in. LCD TV
Vizio model vx322 hdtv10a is losing sound and makes a loud humming noise and a poping sound every few minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | Televison & Video
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Periodically cycles through a loud humming noise.
Hi, these are the early signs of compressor failure. i would put in a service call before it completely fails.
Mar 09, 2009 | Refrigerators
Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
My TV is making cracking noise
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
Oct 30, 2008 | RCA 14F512T 14" TV
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Philips 20PF5120/01 20 in. EDTV-Ready LCD Television Logo
185 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
