Question about GE Microwave Ovens
I have a GE Spacemaker microwave oven that was manufactured in November of 2000. Model No. JVW1631WB 004. KW: 1.58. VAC/HZ: 120/60. The oven no longer heats food. It makes a louder than usual hum when in operation. Is there anything I can do to fix it or should I just chuck it & get a new one? Any help will be appreciated. Thanks.
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile Spacemaker Microwave - won't heat
Thanks for making your post very detailed and including the model number. That really helps! :)
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly easy & cheap do-it-yourself fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 13, 2008
vitg55
  • 70 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
djicenova
  • 319 Answers
SOURCE: Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Posted on Mar 21, 2009
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
  • 464 Answers
SOURCE: I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Posted on Nov 08, 2009
Testimonial: "Thank you great fast advice"
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave just stopped heating this AM. Worked fine yesterday. What's up? It's 10 years old. Model @ JVM163OWB 004
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dj
Aug 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1640BB 004 GE spacemaker Not heating
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.L
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turns on but does not heat
if your microwave does not heat up when turned on its maybe the coil is burnt out are fuse broken, so check your dealers
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
