Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
My lcd will stay on for 5 to 10 minutes and turn off the led light goes from blue to yellow
  • 11,361 Answers
It goes into stanby mode (goes from Blue to Yellow) becuase it may have sensed over voltage or over current draw so it shuts itself down to protect itself. Most problem is either the power supply or the backlight inverter board. You need to inspect the two modules out.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
Posted on May 19, 2010
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
When I have it plugged in, I get the yellow led light. Then when I push the power button the led turns blue, and the unit powers completely off, then goes back to yellow led.
it might be the problem with the internal wiring circuit ,...but not with any led lights. to get more information on led lights and led light bulbs visit ....
www.wholesaleledlights.co.ukwww.ledstriplights.co.ukwww.;ledtape.co.uk
Nov 29, 2011 | Element Electronics FLX-2210 22 in. LCD...
THE tV GOES BLANK WITH NO SOUND 5-10 MINUTES AFTER TURN ON. The blue pilot light in front stays on and sometimes goes yellow . The Tv will sometimes work again if I turn it off and them back on.. Model...
Power supply board is going.Not giving the right voltage to the tv anymore.That why,power it is not consistance.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 26, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
TV won't stay on for more than 10 minutes. Won't turn on at all s
Sounds like a power supply issue. Is it out of warranty? If it is, open it up and check the power supply bd. for swollen capacitors....
Apr 07, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Blue light goes out yellow light stays on after computer is turn off
User manual: http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
That is normal condition, yellow = no video signal from PC since PC is off or PC in standby mode.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Yellow light on - N series router
the yellow light is for processing data
Jan 12, 2009 | Linksys Wireless-G Broadband Router
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
380 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
