Question about Dell 924 All-in-One InkJet Printer
Cannot change "mode" to "printer"
I have a Copy-scanner-printer. Try to change mode to "printer and just leeps saying copt-scan-copy-scan. Cannot bring up printer function so am unable to print anything.
  • 16 Answers
SOURCE: Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Posted on Mar 19, 2008
MsMitch
  • 41 Answers
SOURCE: Scanning function doesn't work
If it copies fine, then it IS scanning. If you are trying to scan to your computer then you will need to open the program and follow the instructions.
Posted on May 28, 2008
  • 36 Answers
SOURCE: Dell AIO 942 Wont' Scan
try uninstalling & reinstalling the drivers....tht wld fix the issue...
Posted on Jul 22, 2008
SOURCE: Scanner malfunction
JTuohey
I had the same problem and just successfully repaired. Uninstall driver and reinstall. Worked perfectly!! Good Luck!!
Posted on Aug 29, 2008
SOURCE: Dell 962 Printer won't scan
my scan light will not work
Posted on Jan 18, 2009
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
Canon mp550 will not scan
use a different scan mode,like the one that came with computer
Apr 28, 2017 | Canon PIXMA Office Equipment & Supplies
Canon mp190 error e5, with refilled cartridge will not reset, even though the error only came on after the printer had already worked with the newly refilled cartridges. Ive tried the reset/power button...
Hi. Try to reset the printer using the procedure below.
Manual Reset for Canon Pixma MPC190 Printers
  1. Enter the service mode SERVICE MODE – pressing buttons Menu, Copy, Scan, Copy, Copy
  2. Choose TEST MODE.
  3. Select 8 PRINTER TEST TEST MODE.
  4. Choose 3, EEPROM CLEAR
  5. Select 0, INK COUNT
  6. Press the Set button.
  7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
Aug 21, 2010 | Computers & Internet
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
When trying to scan from the computer or printer to computer, I get an error that says "scanner cannot be initialized, scanner communication error"
A hardware issue is the most likely culprit. You can test that by trying to to a copy from the machine with the computer off. (most scanners have a "copier" function that lets you copy a paper directly to another paper) If you can copy a document or image there, then it's not the scanner, and a new cable might resolve the problem. If you can COPY from the copier, and you have a new cable, but the issue persists, then you would know it is a software issue rather than hardware. In that case, have a technician walk you through removal and reinstallation of the driver and scanning application, OR, try scanning from another photo application, such as MSOffice Photo Editor.
Aug 31, 2009 | HP Photosmart C5580 All-In-One InkJet...
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
The scanner cover is closed, however I get an error message saying it's open. The unit will not print, copy or scan
I just changed the cartridges, however I get an error message saying " Cover open / close cover / change cartridge " error . The unit will not print, copy or scan. Any suggestions? Thanks
Jul 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Printing - using the 'copy' mode of the scanner
This suggests the the 'copy' element of the software is not VISTA compatible. In VISTA help in my computer - check out the 'compatibility' options and select an operating system that the copy function did work under
Aug 31, 2007 | Canon CanoScan N640P Flatbed Scanner
Dell 924 All-in-One InkJet Printer Logo
15 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
