Question about HP LaserJet 3050 All-In-One Printer
My printer is showing the error message "no printer cartridge" even though there is one installed. I have tried two different printer cartridges with teh same result. It has been working fine for years until this. Bob
ctf1800
  • 4402 Answers
SOURCE: Color cartridge not properly installed
are you sure you have the exact same print cart and not some rebuilt? also make sure it's firmly inplace,
Posted on Dec 04, 2007
hvpatel
  • 152 Answers
SOURCE: HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Posted on Mar 29, 2008
osram
  • 20 Answers
SOURCE: check drum cartridge
You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
Posted on May 13, 2008
SOURCE: Remove and check color cartridge
the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
Posted on Jul 31, 2008
SOURCE: Missing Toner Cartridge
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Posted on Nov 09, 2008
Xerox phaser 6140
Hi Anonymous,
I suspect you should have this problem sorted by now.
Looking at the Xerox website says that a replacement printer is available for around £190 that could have worked out cheaper that trying to get this one repaired.
Replacement Xerox 6500
Good Luck.
Jun 17, 2014 | Xerox Phaser Office Equipment & Supplies
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
HP Laserjet M1522nf - displaying an "install black cartridge"
this error can be caused by a paper jam, or a little piece of paper in the toner area, Take the cartridge out and use a flashlight to check in the sides looking for paper. Other reason is that sometimes the sensor that detect the toner is out of place and in that case you can try to power cycle with the toner out before you install it again. Good luck
Sep 08, 2010 | HP LaserJet M1522nf Multifunction Printer...
NO CARTRIDGE message when new cartridge installed
Make sure there is ink in all cartridges and unplug the machine. Plug it back in while you hold the stop key and it should clear the error.
Nov 23, 2009 | Brother Multi-Function Center MFC-240C...
Error message on hp deskjet printer
I had a similar problem when I tried to install a refilled HP cartridge. I took the cartridge out, unplugged the printer (hard boot), plugged it back in and reinstalled the cartridge. That got it to work.
If that doesn't work, try taking a cotton swab (q-tip, cotton bud) and clean the contacts on the ink cartridge. Even though they are gold plated, sometimes contamination will cover one or two contacts so the printer will not properly read the cartridge.
Hope this hleps....
Aug 04, 2009 | HP DeskJet 3650 InkJet Printer
Even though I have install the ink cartride
Hi there please try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
Printer ink cartridge not recognized by printer hp psc 1210
some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Feb 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Installed color cartridge all of a sudden is not recognized.
Even though the cartridge was fairly new, I replaced it and that solved the problem.
Dec 03, 2008 | Dell 962 Photo All-In-One InkJet Printer
I have a HP 6656A Printer Cartridge that sometimes works good and other times will fail the power on check. Error message varies between Ink Cartridge not compatabile, Check Color Cartridge (even though...
I got hold of another set of 56 and 57 Ink cartridges. By swapping the four of them in and out of two printers, I determined that one of the Black 57 cartridges was bad and caused a missleading error message to pop up saying to check the Color 57 cartridge. I don't know why I was getting different messages at first, but after several swaps in and out of two printers, the error message finally became consistant and I learned that the one Black 56 cartridge was the faulty guy. One Color 57 cartridge printed good but the other (newer one) left streaks on the Cyan and Magenta colors even after soaking the head surface for a few minutes and cleaning it with inkjet cleaner fluid.
The end result is that I have one good Color 57 cartridge and one good Black 56 cartridge which work good in two different printers.
By the way, can you email a labled pinout reference drawing of the hp56, 57 & 58 Ink Cartridges???
Reggie Bostwick
Jul 07, 2008 | HP Office Equipment & Supplies
HP LaserJet 3050 All-In-One Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
