Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
How do i clean the filter on an LG Tromm front loader?
  • 343 Answers
The pump filter is accessed via the small hatch at floor level. It can also be behind the kick plate..Unscrew the filter and clean. It may be very badly clogged with whatever is left in pockets. Remember when the filter is removed the water will drain out..Also, check that coins haven't jammed the impeller. Leaning the machine back against the wall will stop the last of the water from draining and will allow better visual inspection...Good luck...Nomess
Posted on Apr 24, 2010
Why is my LG front loader leaking from bottom front of washer?
When cleaning the filter you may have dislodged the o-ring seal on the filter unit. Check the condition of the seal or if missing replace it with a new one.
Sep 13, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
We have an LG Tromm Steamwasher WM2487HWM . 4.0 cu ft front loader....I see a lot of complaints about mildew and smell...we have the same problem....is it safe to take teh rubber seal off the washer to...
Replace the boot with new. While you have top and front off to replace boot, hose the drum down with a hose on stream. Remove filter clean out as you hose it down. Btw, there is no cleaning off the boot if it has mildew/mold on it.. it's slightly porous and no eliminating it
Aug 05, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front loader will tumble but wont spin
Open the access door at the bottom left corner of your washer. Use the small hose there to drain the remaining water from the machine. Un-screw the big knob next to it and pull out the attached filter. Clean out the filter and re-install. If the filter was clear, replace drain pump motor.
Mar 15, 2011 | LG WM2277H Front Load Washer
What does a pump filter consist of on a front loader tromm
Get some towels ready for the floor'
Open the small door on the left side bottom
Unscrew the large black cap pull out and clean filter
Jul 02, 2010 | LG WM-2277HW Front Load Washer
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Have a lg tromm front loader and am wondering if it is ok to run regular detergent instead of the hd stuff. C.
Not recommended. When buying the correct product you should also find the front loader much more economical on washing powder than a top loader.
Mar 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
332 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
