Question about Kenmore 64823 Top Freezer Refrigerator
How to clean cooling coils - Kenmore 64823 Top Freezer Refrigerator
    Problem Solver:
  • 20 Answers
IF YOUR TALKING ABOUT THE CONDENSER COIL ON THE OUTSIDE USED COMPRESSED AIR..A REAL PAIN BECAUSE YOU WILL NEED TO TAKE IT OUT SIDE..EVAP COILS ON INSIDE A LOT EASIER..BUT YOU HAVE TO REMOVE THE PERISHABLES AND TURN OFF UNIT AND OPEN DOORS AND DEFROST...ONCE THE WATER IS REMOVED PLUG IN...RDS
Posted on Apr 23, 2010
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
Not cooling low enough
Hello, A refrigerator or freezer that is not cooling, but cooling poorly, may have a problem in one of several areas:
EVAPORATOR COILS or
CONDENSER
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust,lint,and dirt.
EVAPORATOR COILS:Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build up, is the presence of any frost or ice build-up on the inside walls,floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gasket.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. if one of the components in the self-defrosting system fails, the refrigerator continues to try to cool.
Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting
system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to off, and leave the doors open for 24 to 48 hours (be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually". When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat(also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor.You may need to consult with a qualified appliance repair technician to further diagnose the problem.
CONDENSER: Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt, or lint, the refrigetator may not cool properly. The coils may appear to be thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and a vacuum cleaner to clean the coils of any lint,pet hair, etc. You may not be able to get to all of the condenser from the front , it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Thanks
Jun 20, 2010 | Frigidaire FRT18FS6C Top Freezer...
A/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Jun 03, 2010 | Weather King 12AJA4201AH Air Conditioner
Ilet the filter on my unit get clogged and it quit cooling. after i cleaned the filter it still doesn't cool.
"If your dirty filter caused your problem,' it was because it restricted the air flow across the cooling coil. Often if the filter is clogged then the air will divert around the filter itself - and clog the cooling coil too, in which case you will need to clean the cooling coil.
The cooling coil is looped in a coil (hence the name) and is comparable to a car radiator. You will need to clean the fins (that are entwined around the coil) so that air - can flow unrestricted, over the coil.
This can usually be accomplished with a brush of some sort. Often you can use your fingers to peel the moist mat of hair and dirt off the front of the coil.
The problem (usually) is getting to the coil, because once you get to it - it generally is not that hard to clean. Your goal is make sure air flows thru the fins and over the coil - unrestricted of dirt, hair, or whatever.
Remember - many things can cause an AC unit to 'not cool' besides the filter being dirty - which is why I prefaced my answer with 'if your dirty filter caused your problem'
Good Luck!
May 02, 2010 | Dometic Rooftop RV Air Conditioner
Fridge is not cooling or freezing,a new timer was put in but stil
Try cleaning the coils under the unit, if you have pets, fur and dust builds up on the coils and the unit will appear to run all the time but will not cool.
Cleaning of the coils should happen at least twice a year, its a common thing to over look by everyone.
Hope this is all it is.
Sep 05, 2009 | Frigidaire FRS3R5EMB Side by Side...
Have Rheem 5 ton heat pump with stacked coils poor cool.
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
Jun 18, 2009 | Ruud Central System Air Conditioner
Heat pump not cooling after 1 hour
Yes it is true . Sound like you are low on freon the unit is shutting off on the low pressure switch or high pressure switch is the outside unit clean ?you may need service. Tom
Jun 17, 2009 | Carrier CARH09K Air Conditioner
Frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May 27, 2009 | Refrigerators
My AC not cooled enough
Make sure that the filter is clean, the evaporator (indoor) coil is clean, and that the condenser coil on the outside is clean. After you have cleaned everything and it still doesn't cool, the unit is low on refrigerant.
Mar 20, 2009 | LG Heating & Cooling
Kenmore fridge not cooling
is the compressor really hot? If so you are low on frion.
Nov 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 64823 Top Freezer Refrigerator Logo
71 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
