Question about Minolta DiALTA Di183 Copier
How do i enter the service mode on a minolta Di183
  • 1,110 Answers
Press "meter count" then stop, 0,0, stop, 0, 1
So 7 key presses. Meter, Stop, zero, zero, stop, zero, one
Do not make any changes while in the service mode unless you are sure of what you are doing. I say this assuming you are not a service tech.
Good Luck and Thank You for using Fixya.
Posted on Apr 23, 2010
3 Suggested Answers
gp3399
  • 34 Answers
SOURCE: Minolta DiALTA Di183 Grayscale Copier
Contact for Konica minolta, Canon copier for repairing/rental/amc/fsma.
We provide CANON IR SeriesDIGITAL PHOTOCOPIER for rental basis also, our rental prices per month 3500/- with free 10,000 copies pre month.
New Delhi & NCR.
Gaurav Pahuja : 9811139117, 9990258388
Posted on Jul 02, 2011
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
DIALTA DI 183. What does code CO3FF indicate?
Minolta di183 C03FF
minolta di183 C03FF Go to Adjust Mode 11, change the setting from 0 to 1.
Sep 08, 2015 | Minolta Office Equipment & Supplies
How do i change the code from 0 to 1 in code error ff c03 in minolta dialta 183
Looks like you have a problem that require machine in adjust mode that enter service mode them press stop start
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 29, 2013 | Minolta DiALTA Di183 Copier
How do I stop the maintenance indicator light in Minolta di183 photocopier? pls help
Call in a service tech to replace the parts that are at there service interval. Seems pretty logical to me.
Jun 12, 2013 | Minolta DiALTA Di183 Copier
Minolta DiALTA Di183 Grayscale Copier Logo Minolta DiALTA Di183 Grayscale Copier printer driver problems
New Delhi & NCR.
Jul 01, 2011 | Minolta DiALTA Di183 Copier
Cannot close the M1 part of Minolta Di 450
M1 is a counter for maintenance need to get service mode access to clear the counter and clear the message.
Dec 30, 2010 | Minolta DiALTA Di183 Copier
Minolta di183 C03FF
Nov 01, 2010 | Minolta DiALTA Di183 Copier
C03ff
CAUSE: Incorrect setting. This can occur after a memory clear is performed.
SOLUTION: To correct the C-03FF code, set the machine to the correct speed by performing the following:
1. Enter the service mode.
2. Select 2 for the adjust mode.
3. Go to setting AD11.
4. Set AD11 to "1" for 18 cpm.
5. Exit the service mode.
to access the service mode .enter UTILITY KEY STOP 0 0 STOP 0 1 .GOOD LUCK
Jul 18, 2009 | Minolta DiALTA Di183 Copier
Minolta Di183 display shows 88
1 Call the Utility Mode to the Display.
❍ Calling the Utility Mode to the Display (p.7-1)
2 Making sure that “U--” appears on
the Display, enter “5” from the 10-
Key Pad.
3 Press the [Start] key.
Enter the 6-digit administrator
number from the 10-Key Pad.
? Do you know how to enter the
administrator number?
➜ Enter the six digits successively.
? Do you want to correct a wrong
number just entered?
➜ Press the [Clear] key and then
enter the correct number.
5 Press the [Start] key.
6 Check that “Ad-” appears on the
Display.
7
Enter the code assigned to the
desired subfunction from the 10-
Key Pad.
? Do you know the code for Copy
Track?
➜ To select Copy Track, enter “1.”
? Do you know the code for Disable Auto Shut OFF?
➜ To select Disable Auto Shut OFF, enter “2.”
8 Press the [Start] key.
GO to Konicaminolta US website down load a operators manual free
Jan 26, 2009 | Minolta DiALTA Di183 Copier
Hi i have photo copier minolta dialta di183
Enter the admin mode (U-5) by holding down the Panel Reset key for 3 seconds (until "U- " appears in the display), entering the number 5 from the keypad, and pressing the start key. Enter the 6 digit administrator code and press the start key again. The display should show "Ad-". Enter 1 from the keypad and again press the start key. The display should read "0". Hit the clear key, enter "1" and hit the start key yet again. Hit Panel Reset several times (or turn the machine off and back on) to return to normal operation.
The default administrator code is 000000.
If you do not know the administrator code, it will be necessary to reset it using the tech rep mode. Enter the tech rep mode by pressing the Meter Count key and hitting "Stop - 0 - 0 - Stop - 0 - 1" quickly. Then hit 7 and the start key. The administrator code will flash. You can write it down and use it, or hit the clear key and enter a new code, then the start key. Exit as above.
Jul 03, 2008 | Minolta DiALTA Di183 Copier
Minolta DiALTA Di183 Copier Logo
369 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
