Question about Canon imageCLASS MF5770 All-In-One Laser Printer
ImageCLASS MF5770 error e100 - Canon imageCLASS MF5770 All-In-One Laser Printer
  • 3 Answers
SOURCE: ImageRUNNER 1600 E100 System Error
if a little part of drum is broken the door of laser is closed. J am sorry for my english .
Mario. (Rome-Italy)
Posted on Feb 07, 2008
  • 66 Answers
SOURCE: E100 error
Hi Paikin,
The error code 100 - Excessive Repeat Protocol during Transmission. Causes
1. Poor line condition.
2. Low transmission level.
3. Echo on the line.
Try reducing transmission spped.
Rgs
S88
Posted on Dec 19, 2008
  • 489 Answers
SOURCE: Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
Posted on May 28, 2009
  • 16 Answers
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Posted on Jul 15, 2009
SOURCE: canon-lbp2900-error-code-e100-0000.
J AI UN IMPREMANTE CANON 2900APRES L INSTALATION ELLE S AFFICHE UN CODE E1000000 J AI FAIT BEAUCOUP D ESSAY POUR ARRIVER A RESODRE SE PROBLEME MAIS J AI PAS ARRIVE JE DEMANDE AIDE ET MERCE BEAUCOUP
Posted on Apr 12, 2011
Canon isensys MF8180C show System Error E100 while printing operation.
This error means: there is a problem with the laser unit. Dirty or faulty
Jun 20, 2015 | Canon imageCLASS MF8180C All-In-One Laser...
Imageclass d530 error code e100 0001
Hi, tahta erro indicates a malfunction in the laser unit, probably dirty or defective
Jun 11, 2014 | Canon imageCLASS MF5770 All-In-One Laser...
E100-0001 error
When there is an error E100-0001
Thus with the PSU is OK, replace the formatter board (main board) does not bring results. Problem is the plastic laser sensor, which came out of the seat (mine). Such cakes ...
The same problem was solved by restoring the electrical contact in the connector J801 LSU (laser unit). Simply reconnect the cables and adapters!
Apr 06, 2014 | Canon ImageClass MF4412 Toner Black Repl -...
Error code 100 0001 imageclass
Cannon. imageclass mf 4750. e100-0001 error who clear
May 14, 2013 | Zebra (282Z-21401-0001) Thermal Label...
Mf4410 error code e100-0001
Code error e100-0001 canon 4430
Was This Helpful?
Sep 17, 2012 | Canon I-Sensys Mf4410 All-In-One Laser...
I fixed a paper jam in my Imageclass D320 printer/copier which involved removing both panels and the ink cartridge to get the paper out. Now it says System Errir E100 and I can't figure out how to fix...
E100 is error for laser unit.
Probably the jam occured because fault on laser unit. To fix error you need to reconnect all connectors of laser unit, or in worst case replace laser unit completly.
Call service...
Hope that helps!
Aug 01, 2011 | Canon imageCLASS D320 Digital Copier
My cannon imageclass D320 may have gotten too cold, do you think that would cause it to display E100? How do I fix it?
E100 error is a faulty laser scanner / laser beam detection error.
You will need a technician to fix this.
Dec 05, 2009 | Canon imageCLASS D320 Digital Copier
Canon D340 error
Check that all the doors are shut. If that does work unplug the printer and the E100 error code should stop.
Aug 22, 2009 | Canon imageCLASS D320 Digital Copier
Canon ir5070 i have an error code e100-00001 what does this mean
E100 code
Laser Shutter not opening
Possible mechanical failure or cracked/damaged Primary Fan Duct preventing the Laser Shutter from opening fully.
May 16, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon imageCLASS MF5770 All-In-One Laser Printer Logo
202 people viewed this question
old marine
old marine
