Question about Garmin Nuvi 660 GPS Receiver
My garmin nuvi 360 will not aquire satellites, or loose them quickly when it does
  • Garmin Master
  • 2,130 Answers
Please see this link on how to get this problem resolved.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Apr 25, 2010
2 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: Lost satellite reception
This problem is not caused by poor solder joints. It's caused by a defective part. We sent a "marked" defective unit to the repair shop mentioned above and upon its return, disamantled the GPS receiver assembly and made the following evaluation:
1. The shop did NOT replace the defective component causing the initial problem in the 1st place. The defective part was STILL in the circuit.
2. The shop placed a wire jumper between the internal antenna and the external antenna port. This type of modification places a +2.5VDC bias on the internal antenna and essentially shorts the internal antenna to the external antenna (when connected), giving unpredictable results. It also affects the circuit impedance and signal strength. This is not the correct way to resolve this issue.
3. The defective part needs to be replaced with a higher rated part. This type of repair returns the unit to full functionality and allows the unit to properly switch between the internal and external antenna as it was intended to do by design
- Jim
SHARCNET-USA
Comments: I will aso add, as the part deteriorates, it becomes resistive and can eventually short out and shunt the incoming RF signal to ground......EVEN with the jumper procedure performed by the shop mentioned above.
- Jim
SHARCNET-USA
Posted on Feb 17, 2010
Will not aquire satellites
This is a common problem on the Nuvi 3xx and 6xx series and is caused by a failed component. Please see this link for troubleshooting information.
- Jim
Nov 23, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin 200w has trouble aquireing satellites?
Go to the Garmin dot com website and follow prompts to download the software and the firmware and software updates - they are free.
Jun 12, 2010 | Garmin nuvi 200W GPS Receiver
I have a garmin nuve 1300.. and it keeps on saying aquiring satellites i have tried all aspects of trobleshooting... can u suggest anything different
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Feb 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
Wrong starting location
you didnt mention it but i assume its not aquiring the satellites. got to the link below and update your unit if you havent already. if you have that already, the link also explains the hard reset.
Aug 07, 2009 | Garmin NUVI 360 GPS Receiver
Nuvi Blackout
This is a known problem that Garmin is fixing. Look at:
http://www.garmin.com/garmin/cms/site/us/support
Under "TOP FAQ" there is an entry for "My nuvi 755T, 765T, 775T or 785T will no longer turn on."
You will need to return your unit to Garmin for them to fix it.
Jun 25, 2009 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 310 satellite aquire problem
I have a Garmin Nuvi 350. I solved the problem by purchasing a Glisson GPS antenna that plugs into the external GPS connector on the Garmin antenna.
Apr 04, 2008 | Garmin GPS
Garmin 360
have you ever updated the firmware (webupdater @ www.garmin.com)?
Dec 12, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
108 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
