Question about JVC MX-D8T Shelf System
Regarding JVC MX-D8T,2 small speakers don't work
Regarding JVC MX-D8T....2 small speakers don't work?
  • wilsoea
    wilsoea Apr 09, 2013
    I am having the same problem. If you figure it out let me know.
Connect JVC MX-GT88 speakers to a differant reciever
If it has a bi-amp, you can connect the speakers to it. By the amplifier, if it's a stereo with bi-amp, be sure that it has at least 400 watts and up in order for the speakers to turn out great, if a receiver like a integrated amplifier, it may have like 2-10 connections, you can connect the speakers all together if it has more than 3 connections, if below 3, you may need to take the speakers apart and make it 3 way by connecting one wire to the tweeter, another wire from the tweeter to the main or mid speaker then one more wire from the main or mid speaker to the sub.
Feb 03, 2014 | JVC MX-GT88 CD Shelf System
Jvc home component mx-kb30 protect mode on
First check that the speaker wires are not shorting, if okay! the problem is in the audio output stage of the receiver, the protect mode comes on if a load is detected.
Apr 25, 2012 | JVC MX-KB30 300W Mini Home Audio System...
JVC TH-V70 Shuts Down
Hello
Even after disconnecting the speakers, the systems shut down, means that there is something short inside the set. Normally, the output amplifier section circuits will have the short. The set need service, and may have to replace the audio output IC of audio secion. Contact the nearest JVC authorised service center at your town. OK.
Jan 24, 2012 | JVC MX-GC5 CD Shelf System
My jvcMXGT90 keeps shutting off the audio keeps shutting off when ever the jvc is cranked past 15 and the bass is on levle four what should udo??
Turn it down or it will turn itself down permanently.
http://www.retrevo.com/support/JVC-MX-GT90J-manual/id/314ci360/t/2/
Read the paragraph labeled "CONNECTION" on Page 2 of the SP-MXG70 (last) part of the document.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
Aug 24, 2011 | JVC MX-GT90 CD Shelf System
My JVC mx-gc5 stereo says protect and then shuts off
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
Dec 12, 2009 | JVC MX-GC5 CD Shelf System
Displays "Protect" on screen
the audio amplifier output are fried
Dec 03, 2008 | JVC MX-KB30 CD Shelf System
Speakers
Your system not being a real powerhouse to begin with, I'd find the most efficient speakers available (read: small) and cable each channel like the picture near the bottom of this link...
http://wolfstone.halloweenhost.com/Audio/audcon_ConnectingAudio.html
The two points at the left are your speaker terminals. Plus on top, Minus below.
Apr 25, 2008 | JVC MX-D401T Shelf System
81 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
