Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Refrigerator side light is out, but the compressor sounds like it's still running, plus the food is still cold. Interesting, when I turn the control knob to off, the light comes back on, but the compressor stops. When I turn the knob back to a normal setting (e.g., 4), the compressor starts back up but the light goes back out. Is this a control board/timer issue as well? Refrig is a 2004 model.
  • 27 Answers
Have never seen a ref of this style with a control board I would say you have some sort of wireing short. if the control is turned off the lights will still stay on, but they also should be on when if running
Posted on Apr 23, 2010
GE Profile refrigerator does not get cold enough to keep food. The compressor is humming but even after having it plugged in for 3 days it has not frozen anything or kept any of the food cold.
Could be the t stat not shutting the unit off..so it runs all the time untill it freezes the evaporator in the the freezer then it runs and runs and gets hot...or if it has had a compressor replace before..the freon level what not put back in thr right way..meaning its overcharged, or undercharged..this will also do this...The coils are dirty under the unit...
May 29, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Freezeing food, milk fruits no control over it
Most likely, the damper door in the air control tower at the top back of the refrigerator section has broken, so that cold air from the freezer is entering the refrigerator whenever the compressor is running, instead of only when the refrigerator section needs more cold air. I beleive you will need a part number WR49X10091 to repair it.
Oct 29, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My compressor runs but I think it shuts off and stays off too long...the box gets to warm and the ice starts to melt before it starts again
First of all, before you do anything, clean the coils under the refrigerator. I couldn't tell you how many refrigerators I've 'fixed' that needed nothing more than the coils cleaned. Dirty coils can cause a multitude of problems, many of them with the exact same symptoms that would be expected when refrigerant components fail. Dirt is the #1 enemy of any refrigeration unit.
If that doesn't help, since both sides of the refrigerator get warm before the compressor kicks back on, I'd suspect the fresh food temperature control thermostat. Not an easy fix for the average homeowner unless you've got specific skills in appliance repair.
Before you do anything, try this. Turn the fresh food thermostat all the way up, the set the freezer setting at a higher than normal setting. The way the system works is that the fresh food thermometer turns the compressor on and off and the freezer control simply controls how much of the cold air from the freezer is diverted to the fresh food compartment.
If you turn the fresh food thermostat higher, the compressor will run longer and adjusting the freezer control to a higher setting will allow less cold air into the fresh food compartment, forcing the compressor to run longer in order to cool it to the thermostat setting.
If the settings have to be abnormally high, this is a workaround, rather than a fix. To get a permanent fix, you'll probably have to replace the fresh food control thermostat.
I hope this was helpful to you or to anyone reading it.
Oct 10, 2009 | Amana Refrigerators
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Maytag Plus side by side (Model MSD2356AEA)not cooling in
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Wide by side refirgertor side not getting cold
Remember, the control for the cold food refrigerator is merely a vent control.
If you can get no frost on the coils while the compressor is running, you then look at the condenser then the compressor (coolant charge).
Jun 26, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Whirlpool gold side by side refrigerator relay compressor?
turn it off for an hour or so and give the coils time to thaw just in case they somehow froze up. also if the frig was tilted in the wrong direction (which it doesnt sound like it was since it has food in it!!!) it could need time to let the refrigerant and oil settle back into the compressor.
where are you located (cold or warm climate)?
and where is the frig located (in your home)?
Jan 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
