Question about Canon PIXMA MX310 All-In-One Printer
Paper feed problem
My Pixma initially draws the paper in to print, starts printing but does not continue to progress the paper; then stops and gives the message that there is a paper jam, though nothing is jammed. Basically the paper won't feed past the initial start. I've cleaned the roller but it hasn't helped
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Posted on Mar 04, 2008
  • 21 Answers
SOURCE: printer keeps saying paper jam..there is no paper jam
You can also try using a rubber eraser as the rollers are going. Just take a pencil and lightly rub along the length of the rollers as they are feeding. This should remove the film that clogs the rollers surface.
Posted on Jan 14, 2009
yooperbud
  • 8637 Answers
SOURCE: mp810 paper feed issue
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
SOURCE: PAPER WON"T LOAD
The problem is software rather than mechanical operation. Uninstall the printer driver from the Add/Remove section of the Control Panel. Pull out the USB port and replace it back. This will prompt you pc to install the driver of the newly found hardware. Reinstall the printer driver. Should your printer be observed to have the usual problem, replace both cartridges with a one. "Loading paper" problem feedback is the same prompt as what you get when cartridges are old or refilled with unauthentic ink.
Posted on Feb 18, 2009
APremkumar
  • 564 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
Posted on May 26, 2009
Canon Pixma iP 6600D printing problem.. went to print a scanned document .... paper began to feed in askew from autopaper feeder . Printing process stopped. the process was repeated a couple more times...
To fix the paper feed problem, Clean / rub each roller with a damp cloth with a dab of detergent.
Check for paper residue , especially near the paper empty flag,
Then reset the printer:
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Loaded paper, not printing
Check the feed switch, you have a choice to put paper in the back slot or the cassette under the front. You change from one to the other by pressing the feed switch and an indicator on the panel tells you which one to put paper in.
Jan 13, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feed and printing problem
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others, it seems to reset the sensors or something.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
hope it works, let me know, Garty
Apr 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
