Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
My steam vac stopped sucking up the water. How do
My steam vac stopped sucking up the water. How do i troubleshoot this
  • 438 Answers
Hi There,
Here's a link to the instruction manual for your Hoover SteamVac. There is a trouble shooting guide in the back of the book that will explain how to check no suction problem.
If none of these suggestions fixes your machine, please just refer to my answer below the link, these are the problems you may have.
Here's the link:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furnitureMy steam vac stopped sucking up the water.  How do - 2_bing.gif and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thanks,
Chris Jones
GoVacuum.com
Posted on Apr 23, 2010
5 Suggested Answers
SOURCE: I am using a hoover
Have u tried cleaning it out really good make sure any areas that water is **** up through are free of hair, lint ect.
Posted on Sep 07, 2008
  • 97 Answers
SOURCE: steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Posted on Aug 02, 2009
  • 120 Answers
SOURCE: My steam vac stopped sucking the water up
make sure the lid on the dirty water container is on tight and the tank itself is locked into place, also check to make sure the clear window in the front of the machine is tightened down firmly
Posted on Oct 21, 2009
mindreader
  • 578 Answers
SOURCE: my hoover spin scrub steam vac stopped sucking up
Only 2 possible probelms.
The vacuum adapter in missing from the dirty water tank.... OR the intake part of the machine is clogged and must be cleared of hair and dirt (with the supplied plastic wand)
Posted on Nov 25, 2009
Steam vac won't suck up water from cleaning rug. I did not press trigger for vacuum, I checked vacuum, brushes and recovery tank. All look ok.
Check the little gate on the back of the return tank and make sure it is seated well. If not seated it will stop the water pickup.
Jul 16, 2017 | Vacuums
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My hoover spin scrub steam vac stopped sucking up water
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Oct 20, 2009 | Hoover F5858-910 SteamVac Vacuum
Steam vac won't **** water
Jul 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover Upright Steam vac
Is there a float switch in the tank? Could be when the float rose up to a level it got stuck, stopping your machine.
Sep 09, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
1,143 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
