Question about Stoves Premier 600EMa Electric Single Oven
Stove won t work
My oven quit working how can i fix it
  • Stoves Master
  • 43,501 Answers
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 26, 2010
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
Stove oven not working properly
Could be any of a number of things, or combination of them.
1. Power? If the oven is electric, does the light work? If not, might need to flip breakers at the panel.
2. Thermostat is shot. Also the sensor bulb may be broken or defective inside the oven.
3. Element burned out. This is quite common. If you can cut the power to the oven, and remove the element and test for continuity with a meter, that would tell you if it needs replacing.
Nov 07, 2013 | Stoves Ovens
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven quit working . Stove top burners work just
if its an electric start. then the problem is usually the ignitor for oven. if you change this yourself, be carefull they are very fragil. hold on to igniter by its base. slide ignitor into steel case then install. and hook up the 2 wires for ignitor.
May 14, 2010 | Ovens
Stoves Premier 600EMa Electric Single Oven Logo
166 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
